baffled by import image
fritter63
Message 1 of 30
fritter63
I've been playing around importing images so they can be traced. I'm confused at what ends up getting imported.
See attached picture. When I import an image, I get a "squished" version of it, the aspect ratio is not maintained from the original image.
However, if I try to scale it by doing the aspect ratio math (in this case 2016/1512 = 1.333), the image does not go back to what it should be. The scale actually needs to be more like 1.6. What am I missing here? Why doesn't it not maintain the original aspect ratio?
Also, is there any plans to add ability to import eps files or such that will get the tracing done automatically?
Thanks.
Distorted and original attached.
Replies (29)
Message 2 of 30
TrippyLighting
That looks clearly like a bug to me!
The metadata on the original image shows Orientation : 6 (rotated 90 CCW)
I simply re-exported it as a jpeg and then the metadata shows :
Then it imports with the correct aspect ratio.
I have attached the  corrected file.
Message 3 of 30
fritter63
Good catch @TrippyLighting!!!!
Hmm... a problem with ios 9? I took that picture with the iphone and then emailed it to myself. Maybe i had it tilted a little wierd? it does show correctly
on the phone though.
I've noticed some wierdness with auto-rotate lately on the phone (videos, images, etc).
Message 4 of 30
TrippyLighting
Maybe, but this is definitely a bug as Fusion 360 seems to ignore the metadata.
Message 5 of 30
TrippyLighting
I've posted  second thread, so this does not get overloked 😉
Message 6 of 30
jakefowler
Thanks for posting this, @fritter63, and nice investigation work @TrippyLighting!
You're right, it appears we're not handling the metadata correctly for this image. I've logged this with our development team to investigate (issue no. FUS-21916, if needed for future reference).
In the meantime, rotating the image before inserting into Fusion, as @TrippyLighting suggests, is probably the best workaround.
Apologies for the inconvenience this causes,
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Message 7 of 30
TrippyLighting
Can we please get this fixed ?
This is still not working as I just experienced with the image from this thread!
Message 8 of 30
jakefowler
@TrippyLighting Sorry, this hasn't been fixed yet I'm afraid 😞 We're looking into it.
Jake
Jake Fowler
Fusion 360
Message 9 of 30
OceanHydroAU
Jake
Hi Jake - any chance you can fix this bug ?  It's been 5 years so far ...
Message 10 of 30
prosmack
This is still going on...
Message 11 of 30
OceanHydroAU
Yes - there are 2 bugs with images:
a) Fusion360 screws up the way it processes the image EXIF metadata (rotation/aspect data) and "squishes" your images
b) When you try to scale it, the scale operations are immediately applied *before* you accept them, so unless you got the fix 100% perfect on your first attempt, anything you tried first will always be making things worse.
I'm not sure how these two VERY simple bugs have managed to evade being fixed for so long !
Message 12 of 30
bbrendon
Is there a work-around for importing an image? When I used fusion on a Windows computer I didn't notice this problem, only on mac.
Message 13 of 30
fritter63
:shrug:  .... I don't even remember the original post. 🙂
Message 14 of 30
TrippyLighting
@bbrendon I described a workaround in the 2nd post.
Not that this bug comes up that often, but it is embarrassing that this still hasn't been fixed!
Message 15 of 30
alphaaPDYTU
Observer
Observer
This issue still  hasn't fixed yet. after 8 years.
Message 16 of 30
alphaaPDYTU
Observer
Observer
any update Jake?? it has been 8 years mate.
Message 17 of 30
atherisinnovations
It's been long enough that Jake may not have the same title/responsibilities anymore..
Message 18 of 30
TrippyLighting
LOL. It's been so long, he might have retired 😉
Message 19 of 30
hfts_rider
Community Visitor
Community Visitor
Somehow it wasn't a problem for some period of time, but now I have the same problem.
Photo was took on Android and downloaded from Google photo on mac.
Solution:
1) Open picture in mac preview
2) shift + command + 4
3) select area to make screenshot
4) upload screenshot to fusion
Message 20 of 30
fritter63
It’s been so long that I not only forgot about the OP, I even forgot about posting that I had forgotten about the OP!
Autodesk needs some DOGEing I think. 😎
