Decal API in direct modeling mode raises "RuntimeError: 2 : InternalValidationError : timelineObj"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I tested new Decal API and it works well in parametric modeling mode. But I think it doesn't in direct modeling mode.
The code below runs OK for parametric modeling mode, but not for direct modeling mode.
import traceback import sys import pathlib import adsk.core as ac import adsk.fusion as af IMG_PATH = pathlib.Path(sys.base_prefix).absolute() / 'Python/AddInSamples/CommandSample/commands/Basic/resources/32x32.png' def run(context): app: ac.Application = ac.Application.get() try: ui = app.userInterface test_decal(app, True) test_decal(app, False) except Exception: msg = traceback.format_exc() print(msg) if ui is not None: ui.messageBox('Failed:\n{}'.format(msg)) def should_true(x): if not x: raise Exception() def create_profile(root_comp: af.Component): s = root_comp.sketches.add(root_comp.xYConstructionPlane) should_true(s.sketchCurves.sketchLines.addTwoPointRectangle( ac.Point3D.create(-1., -2., 0.), ac.Point3D.create(2., 1., 0.) )) return s.profiles.item(0) def create_face(root_comp: af.Component): profile = create_profile(root_comp) pfs = root_comp.features.patchFeatures p_in = pfs.createInput(profile, af.FeatureOperations.NewBodyFeatureOperation) pf = pfs.add(p_in) return pf.bodies[0].faces[0] def test_decal(app: ac.Application, is_parametric_mode): _ = app.documents.add(ac.DocumentTypes.FusionDesignDocumentType) app.activeProduct.designType = af.DesignTypes.ParametricDesignType if is_parametric_mode else af.DesignTypes.DirectDesignType root_comp: af.Component = app.activeProduct.rootComponent face = create_face(root_comp) if is_parametric_mode: base_feature = root_comp.features.baseFeatures.add() should_true(base_feature.startEdit()) o = ac.Point3D.create() di = root_comp.decals.createInput(str(IMG_PATH), [face], o) if is_parametric_mode: di.targetBaseFeature = base_feature should_true(base_feature.finishEdit()) _ = root_comp.decals.add(di)
The exception is "RuntimeError: 2 : InternalValidationError : timelineObj" at "root_comp.decals.add(di)".
