March 2025 Update and Community Bug Fixes (Design)
seth.madore
Community Manager Community Manager
Message 1 of 8
seth.madore
Hello to the Fusion Design Community!
As always, we greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
In an ongoing effort to increase our transparency as well as our communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in each update. The list below comprises all the issues that have been raised by our engaged community. So, without further ado, here is what we're going to see in the March 2025 update (creator of forum thread and the thread itself, in no particular order):
Design
We should now have better Joint behavior when working with Configurations
@AncientCowboy
Our Drawings module should do a better job of dimensioning
@bas1l
API query of Face Entities should return more helpful information
@adminBRJ4S
Measure and Default Measure should always show “Loop Length”
@davebYYPCU
Parametric formulas should produce the same result both visually and computationally
@davebYYPCU
We’ve updated the API Manual for how CustomColors are supposed to work
@joshM57CN
“Canvas” command will now display the  Active Component “Origin”, not the root Origin.
@g-andresen
We’ve improved the SelectionCommandInput validation capabilities
@nnikbin
@rolandas_vegis
Calling command based API during Command.Execute has better handling
@tomas.bangoA2EPZ
Time settings mismatch should prompt more informative error messages
We now let you know when and why a “Delete” is converted into a “Remove” feature
@k.huxmann
We've made some improvements to Constrain and Sketch Geometry
@axel.dumas.kct
Just as in prior updates, this isn’t to suggest that those are the only fixes that we've included in the update. The list above are the issues specific to what’s been reported by the Design community; within this update our team has additionally found and fixed well over 100 different bugs and issues.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks for contributing to what makes the software truly great!
Click here to see release notes from prior updates:
March 2024
May 2024
July 2024
September 2024
November 2024
January 2025
Seth Madore
Replies (7)
Message 2 of 8
hajime2MRG3
Hello seth.madore,
I checked the Fusion 2601.0.90 x86_64, and I could not find any change of the result of   https://forums.autodesk.com/t5/fusion-api-and-scripts/odd-bug-of-decal-api/td-p/13268922 .
Best regards,
Message 3 of 8
seth.madore
I'm just the messenger reporting what we claim to have fixed. I'll touch base with the devs and see if this was a premature announcement on my part 🙂
Seth Madore
Message 4 of 8
seth.madore
It was premature on my end, my apologies. We've fixed it internally, but it looks like it's slated for the next major update (hopefully).
Seth Madore
Message 5 of 8
seth.madore
To clarify your comment though;
In the image you shared above, isn't it showing the decal where it's supposed to be? The image that you shared in your original thread has the decal randomly placed over the faces:
Seth Madore
Message 6 of 8
hajime2MRG3
Thank you seth.madore,
All decals are rotated by the same 1 rad:
But sometimes the rotation is ignored:
And it depends on the extrude length of the cuboids. 0.6, 0.8, 1.2 mm are ignored.
Odd but reproducible.
Best regards,
Message 7 of 8
seth.madore
Ah, I see! I was chatting with the devs about this and it looks like they misunderstood the reported bug. They did solve for the X/Y placement of the decals, but didn't take into account rotation around Z. We've reopened the task and will address it in a future release 🙂
Seth Madore
Message 8 of 8
infoLX9RB
Observer
Observer
After the update, when pressing a face, a torus appears from no where and cuts the body if the push is accepted. No idea what is going on with this one. There is no torus in the design. See attached screen record.
