Forum Reported Fixes March 2024 Update
annaka.ketterer
Autodesk Autodesk
annaka.ketterer
Forum Reported Fixes March 2024 Update:
Each release our team works hard to create a better, faster, more streamlined experience for you all to enjoy. In an effort to increase our transparency as well as our communication with you, the end user, we want to call out all the Forum Reported bug fixes that are included in each update. The list below comprises all the issues that have been raised by you, our customer. The list below are the issues specific to the Forums, within this update our team has additionally found and closed over 200 different bugs. So, without further ado, here is what your going to see in the March 2024 update (creator of forum thread and the thread itself, in no particular order):
Design
@sebastianAL567 We fixed an issue where T-spline curves are far away from surface
@alexpinson5 'Remove' Tool now should work as expected on Linked Components
@Luke_Parf Using the mirrored component ONLY in a sheet metal production work flow should now work as expected
@lelseyRDLG8 Using Move function on Text-on-a-Path Sketch Objects in a Fully Constrained Sketch now works as expe...
@wmhazzard Circular Pattern of Features has been improved
@v.kozachenco How to keep object in specific place or limit its movement?
@jeeyongJK6UT Fusion should now give the correct gumball direction with 'selection space' option.
@lomi043 Convert should now show body
@TonyB64D Filling void between inner cylinder and barrel outer walls should now work as expected
@hectorlandaeta @eliedesmet @carl.j.barker @amy.worrall Export sheet metal design to DXF should now work as expected
@bainvSMPRN We fixed an issue causing Fusion to hang for 10-20 minutes when doing assembly dimensions from other...
@pierre.rebella We fixed an issue causing Configurations to run slowly when opening, saving, and updating configured...
@kamila.bialozynska Sort by name / last updated should now work as expected
@amfinke4TV2G We fixed a crash issue that occurred when deleting components
@israelkeTZC3Q We fixed an issue with occurring with joint origin deletion
@Eric_Evans_a_GiroDisc_com @max.armstrong9BJVM Insert McMaster Component will now load into currently active component
@edgemarston "Manage Lost Projections" UI is now fixed
@ltomuta Right mouse button handling fixed
@19yfiddler @tom.offord @sales.botzlab Coil feature will now allow non-integer values for Revolutions
API and Add
@siliconlad ThroughAllExtentDefinition will no longer fail to extrude
@Jorge_Jaramillo We fixed a bug generated when a closed SketchFittedSpline is broken with breakCurve() function
@karl.ri 'areProjectedGeometriesShown' property in the Sketch object should no longer be missing
@Joshua.mursic We fixed a bug when setting the sketch.transform property
@mcd8604 UnitsManager.formatInternalValue now properly adjusts for precision set in User Preference
@ione_ianniruberto Sketches on plane along a spline should now operate as expected
@robertASTUP We fixed a bug that occurred when getting toolbar panel names from Sketch Toolbar Tab in the Design ...
@ltomuta ProfilePlaneWithOffsetStartDefinition is now changed to "OffsetStartDefinition" and has proper docum...
Electronics
 @infoBKDH3 Push to 3D PCB will no longer cause a misalignment in silkscreen
Manufacturing
Learn more about the Manufacturing fixes here.
Thank you for all your help, feedback, and support. You all are truly an integral part of making Fusion what it is today.
Annaka Ketterer
Prior Lake, Minnesota
Become an Autodesk Fusion Insider
TrippyLighting
Fellow EE's, this post/thread deserves a few likes, so if you haven't already ...
@HughesTooling @seth.madore
@davebYYPCU @jhackney1972 @TheCADWhisperer @g-andresen @etfrench @laughingcreek
Lets adda  few others:
@Phil.E @jodom4 @jeff_strater
seth.madore
Hmm, looks suspiciously like THIS ONE 😁
Seth Madore
TrippyLighting
The hint was received 😉
mikahb
This is a cool post - I'm more new to the Fusion forum than to Fusion, but this level of transparent community engagement and community-driven improvement is (in my experience) super rare.  Good stuff!!
