Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Missing an 'areProjectedGeometriesShown' property in the Sketch object
4 REPLIES 4
karl.ri
164 Views, 4 Replies
Is there a possibility to hide projected geometries?
skt.areConstraintsShown = False
skt.arePointsShown = False
skt.areProfilesShown = False
skt.areDimensionsShown = False
4 REPLIES 4
kandennti
in reply to: karl.ri
Hi @karl.ri -San.
Since it does not seem to be provided in the API, we created a sample using a TextCommands.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = "Select Sketch"
        selFilter: str = "Sketches,SketchCurves,SketchLines,SketchCircles,SketchPoints"
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        hide_projected_sketch_geometries(sel.entity)
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def hide_projected_sketch_geometries(
        sketchEntity
) -> None:
    skt: fusion.Sketch = None
    if hasattr(sketchEntity, "parentSketch"):
        skt = sketchEntity.parentSketch
    else:
        skt = sketchEntity
    sels: core.Selections= app.userInterface.activeSelections
    sels.clear()
    sels.add(skt)
    app.executeTextCommand(u"Commands.Start HideProjectedGeometries")
    sels.clear()
def select_ent(
    msg: str,
    filter: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filter)
        return sel
    except:
        return None
karl.ri
in reply to: kandennti
Thanks for your quick response. Your script runs well on its own, but I have to implement it into my script. The script is not finished yet.
Problem 1: The fusionMoveCommand ist started after the script ended.
Problem 2: The sketch offset is sometimes inside, sometimes outside of the projected geometry.
Problem 3: hide_protected_sketch_geometries does not work
I  am a new to scripting and this is my first try to solve my post
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/move-command-modification-showing-an-exten...
My skript is attached.
kandennti
@karl.ri -San.
When calling the hide_projected_sketch_geometries function, do this.
                skt.createForAssemblyContext(occ)
karl.ri
works great,thank you.
