Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Sketches on plane along a spline
2 REPLIES 2
ione_ianniruberto
123 Views, 2 Replies
Hi, I have created a plane along a spline like in the figure. Now I want to create a sketch on this plane. I create the circle in the plane and as the center of the circle I want specifically the point of the spline in corrspodence of which the plane has been created. I try to put zero but the code gives the result in the figure. The code that I wrote is this:
spline = sketchnurb.sketchCurves.sketchFittedSplines.add(points)
distance0 = adsk.core.ValueInput.createByReal(0.0)
planeInput.setByDistanceOnPath(spline, distance0)
plane0 = planes.add(planeInput)
sketchplane0 = rootComp.sketches.add(plane0) #PianoVALVE
circleplane0 = sketchplane0.sketchCurves.sketchCircles
circle01 = circleplane0.addByCenterRadius(adsk.core.Point3D.create(0,0,0), 0.85)
circle02 = circleplane0.addByCenterRadius(adsk.core.Point3D.create(0,0,0), 1.05)
profilo01 = sketchplane0.profiles.item(0)
profilo02 = sketchplane0.profiles.item(1)
I don't know what else to do. Can someone please help me?
Ione
2 REPLIES 2
For some reason, the origin of the construction plane is not created on the spline. I'm sure there's a reason for this but it's not evident to me.
However, there is a workaround. If you replace these lines
with this
circle01 = circleplane0.addByCenterRadius(sketchplane0.modelToSketchSpace(plane0.geometry.origin), 0.85)
circle02 = circleplane0.addByCenterRadius(sketchplane0.modelToSketchSpace(plane0.geometry.origin), 1.05)
you should achieve the desired result. This substitutes the centerpoint with the origin of the construction plane which is in fact on the spline.
Sample screenshot:
I Hope this helps!
Thanks so much!
