May 2024 Update - Community Reported Bug Fixes (Design)
seth.madore
Community Manager Community Manager
seth.madore
Hello again to the Fusion Design Community!
We greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
In an ongoing effort to increase our transparency as well as our communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in each update. The list below comprises all the issues that have been raised by our engaged community. So, without further ado, here is what we're going to see in the May 2024 update (creator of forum thread and the thread itself, in no particular order):
DESIGN
@wmhazzard
Boundary Fill should highlight properly
@TrippyLighting
Instance counter should do a better job updating with Rigid Groups
@jesse
Units in Sheet Metal should now be accessible via API
@etfrench
We've fixed the ability to create a 1-1/8" -8 UNC thread
@Mikhail_Romanov
The Sketch Solver should now be more robust
@alan.jonesXHXUF
Threads should no longer dissapear after a Derive
@thomasa88
Fixed "InternalValidation when setting SketchText.text"
@kristianY3VSG
Better color schemes for CV spline construction lines
@kdimitoka
Pipe feature should no longer be corrupted
@alex14
Insert divider in command dialog
@neljoshua
Improvements to the Inspect > Measure tool
@lichtzeichenanlage
Editable documents are not released after archiving a project
@wmhazzard
Circular Pattern of Features should now behave more properly
@alex14
You can now insert a divider in your custom command dialog
@dghermann
4.5 TPI threads should now be modeled correctly.
@hajime2MRG3
The folder name should remain for VS Code
Just as in the March Update, this isn’t to suggest that those are the only fixes that we've included. The list above are the issues specific to the Design Forums; within this update our team has additionally found and closed 150+ different bugs.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks for contributing to what makes the software truly great!
Click here to see: March Release Community Patch Notes,
Seth Madore
Mischief_Machine
It would be really awesome if fusion didn't freeze when you tried to drag a surface too far or enter a fillet radius that it cant compute. Why does it just lock up?
TrippyLighting
It makes the geometric modeling kernel go into overdrive, trying to find a solution that satisfies the inputs.
