Circular Pattern of Features
wmhazzard
Advisor Advisor
wmhazzard
I was playing around with this model from Fusion 360 School,
https://www.youtube.com/watch?v=SVs9LbyM2i0
So I did a circular pattern of features of two extrudes and the single body which was named body 2 changed to body 3 after the pattern was applied. It seems like a bug to me, the body should have stayed body 2.
Also, when you move the timeline back before extrude 2, body 2 is above body 1 in the Browser. When you move back before extrude 1 and then forward again, body 1 then comes before body 2.
I have noticed the second annoyance for a long time now, bodies in the wrong order in the Browser but this is the first time that I can document it.
jeff_strater
this does seem like a bug to me.  I will log it as such.  The other methods (Optimized, Identical) fail in worse ways.  I suspect it has to do with the merged face at the top, but that is just a wild guess.
[edit] I created bug FUS-106654 for this issue.  Thank you for reporting it and for sharing the model.
Jeff Strater
Engineering Director
