Inspection Tool Bugs
neljoshua
Advisor Advisor
neljoshua
Sometimes when I am trying to use the inspect tool, I get readings that are not helpful.  I am working in a design that has quite a few XREFs and am trying to measure the distance between two faces.  Here is what I get:
The top face is small, but it is indeed a face.  I know these features are square and are squarely aligned with rigid joints.  Fusion seems to know this too, but reports an angle of 0 degrees rather than the distance.  That is not helpful.  I have seen this in multiple models--not just this one.
If this happens, I re-select the features I want, but this time I use points rather than faces (and look at the xyz delta).  This takes extra time and sometimes does not work.  I have seen the inspect tool report an angle between two points on different components.  This is not right, either.  I do not have a screenshot for this, but it has happened more than once.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
HughesTooling
Does it still show an angle of zero if you set precision to All Decimals?
Mark
Mark Hughes
Owner, Hughes Tooling
neljoshua
@HughesTooling,
I should have checked at that time.  It does, however, still show 0.0 deg if I set the precision to "all decimals".
__
paul.clauss
Hi @neljoshua
Thanks for posting! I have logged an issue with our development team about this problem (FUS-29137). I will circle back here once I have more information to share. I also checked this phenomena in a variety of files and do not believe it to be related to the Xrefs.
For now, I would recommend allowing the Inspect > Measure tool to snap to points on the faces you are selecting and then use the XYZ delta readings.
Kind Regards,
Paul Clauss
Product Support Specialist
neljoshua
@paul.clauss,
Thanks for the update.
__
