Cannot launch VSCode by "Scripts and Add-ins" -> "Edit"
hajime2MRG3
Message 1 of 10
hajime2MRG3
The "Edit" button should launch VSCode. But now, it doesn't. I found it with my Windows 11, and verified with Windows 11 Enterprise Evaluation (here) on VirtualBox 7.0.12. VSCode has been changed something?
Replies (9)
Message 2 of 10
KarlRBS
The same happened to me today. I believe it was a change in the just released v2024.4.0 of the VSCode python extension. Unfortunately, downgrading the extension to the previously working v2024.2.1 did not solve the problem for me. Luckily it was a fairly simple fix for me so we don't have to wait for Fusion to be updated.
All we have to do is edit the pre-run.py file to change "pythonFiles" to "python_files". This script can be found in Fusion by opening Preferences > API and navigating to the "Default Path for Scripts and Add-Ins." From here, we just need to navigate to the ./Python/vscode directory where the script is stored. On a Mac, the full path may look like "/Users/<username_goes_here>/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Python/vscode/pre-run.py". Edit this file and find "pythonFiles" when setting msPythonPath and change it to "python_files". Restart Fusion and you should be good to go with v2024.4.0 of the ms-python.python extension. Here's the full difference:
+++ pre-run.py	2024-04-04
@@ -38,7 +38,7 @@
         msPythonPath = os.path.expandvars(msPythons[0][0].path)
         index = msPythonPath.rfind('.')
         version  = int(msPythonPath[index+1:])
-        msPythonPath = os.path.join(msPythonPath, 'pythonFiles', 'lib','python')
+        msPythonPath = os.path.join(msPythonPath, 'python_files', 'lib','python')
         msPythonPath = os.path.normpath(msPythonPath)
         if os.path.exists(msPythonPath) and os.path.isdir(msPythonPath):
             return msPythonPath
The reason for this change is described in the vscode-python changelog where it notes Issue #22921 "Rename pythonFiles to python_files". Hope that works for you too!
Message 3 of 10
hajime2MRG3
It worked like a charm! Thank you!
Message 4 of 10
OceanHydroAU
me too - worked fine thismorning, now I can't get anything done!
The above solution did nothing for me (Windows 10N)
** Update - you have to close and restart Fusion for this to start working.
Also fixes "debug":
It probably should not be marked as "Fixed" ... editing system files manually is a workaround - someone else really needs to find and fix the root problem here.
Message 5 of 10
JeromeBriot
The above fix did not completely resolve the issue on my PC (Windows 11). There was something wrong with the Python Debugger extension :
20240405T114111 I .15948 VSCode:Starting script run
20240405T114111 I .15948 VSCode:Python manager initializing
20240405T114111 I .15948 VSCode:Running script
20240405T114111 I .15948 VSCode:Running python script
20240405T114111 E .15948 NUBASE.PYTHON: failed to start python debugger:
Traceback (most recent call last):
  File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'debugpy'
20240405T114111 I .15948 VSCode:Launching visual studio code editor failed
I had to downgrade the "Python" extension and the "Python Debugger" extension in VS Code to version v2024.2.1 and to version v2024.2.0
Message 6 of 10
en9y37
It worked to me too. Thanks a lot!!!!
Message 7 of 10
JeromeBriot
On Windows, the pre-run.py file is located under :
C:\Users\<USERNAME>\AppData\Local\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Python\vscode
If you don't find the b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1 folder, search for the newest one.
Message 8 of 10
GAAS.Design
edit: still broken
Message 9 of 10
erik_per_rosen
Observer
Observer
Hey, I tried this but sadly it dosen't seem to work anymore. Is there some other solution?
Message 10 of 10
BrianEkins
See this post for a solution.
https://forums.autodesk.com/t5/fusion-api-and-scripts/can-t-edit-or-debug-my-python-scripts/m-p/1275...
Brian Ekins
