[Script] Import spline from any CSV file
JeromeBriot
Mentor Mentor
Message 1 of 17
JeromeBriot
ImportSplineAnyCSV is an improved version of the ImportSplineCSV script that reads data from a CSV file and creates a spline in a sketch.
This version supports:
  • two colunms and three columns data
  • numbers with a comma as the decimal separator
  • any kind of separator between values
  • automatic text header skipping
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-import-spline-any-csv
Replies (16)
Message 2 of 17
Protective-foam_com
@JeromeBriot
Your script works great!
Thank you for not being indifferent to the problems of less experienced users:)
Message 3 of 17
hibaby
Community Visitor
Community Visitor
I followed your instructions but the error message comes up like this. What would be the problem?
Please tell me what should I do...:(
Message 4 of 17
JeromeBriot
Message 5 of 17
jmpframce
how to use the adress you send
thanks
Message 6 of 17
JeromeBriot
Message 7 of 17
jmpframce
github.com/JeromeBriot/fusion360-import-spline-...
how to use ?  please  i am fully blocked  in writing a process os desining tool
Message 8 of 17
jmpframce
github.com/fusion360-import-spline-...
est cela qu il faut  copier dans les scripts
merci
Message 9 of 17
jmpframce
How to download
Copy in script first
Message 10 of 17
jmpframce
not
how to  load   i don t get message to past in script
hhttps://github.com/JeromeBriot/fusion360-import-spline-any-csvd
Message 11 of 17
JeromeBriot
New version available (1.1.0):
  • Fix unique separator in CSV file reading
Message 12 of 17
jmpframce
Thanks I will install
It for 3D XYZ?
Message 13 of 17
JeromeBriot
New version available (1.2.0):
  • Add feature to import multiple splines from one CSV file
  • Add examples
New version available (1.3.0):
  • Treat line in CSV file as empty if less than 3 characters
New version available (1.4.0):
  • Add option to import multiple splines in a single sketch
Message 14 of 17
JeromeBriot
Message 15 of 17
james_stclair2
Community Visitor
Community Visitor
Hello Jerome, thanks for this script, it is very helpful.  However, some of the splines I import from CSV seem to treat the Origin as a spline point, so the spline goes crazy around that point.  In other words, the spline behaves as though I had the point 0,0 in my data, which I don't.  Am I doing something wrong?  Can you suggest a fix?  Many thanks - James
Message 16 of 17
JeromeBriot
Message 17 of 17
james_stclair2
Community Visitor
Community Visitor
Hi Jerome,
I solved this by just moving the whole spline so the first point was at the origin.
Here's the csv that produced the behaviour, in case it is of interest to you.
Thanks again for sharing your work 🙂
Best, James
