Revit Hints and Hacks: Rollback a Cloud Based Project
Things go wrong sometimes, files get corrupted, someone accidentally deletes part of a project, the project manager wants the other version of the design back, or any number of other events. Sometimes you just need to Rollback a Revit project. Starting in the 2023 version these are the steps from inside of Revit.
  • To view the various versions of an Autodesk Construction Cloud project, first, locate the project in the Project folder.
  • Next, click on the ellipses ( … ) at the end of the name of the project name.
  • Look for Version History in the list of options.
  • This will bring up the history of the project with the version, name of who saved it, any comments put in the saved time, and date.
  • To Rollback to another version, first, make sure everyone is out of the file.
  • Next, click on the ellipses ( … ) at the end of the project by the date you need.
  • Choose the version you want to restore and select Restore to version.
  • Also, consider using this method to find Open and Audit for some problem files.
You do have to be signed in to “Like” a blog post. When it comes to any blog post, sing it with me now, “If you liked it, then you shoulda put a “Like” on it. Sign in and sing it with me.
#CADMama #AutodeskCommunity #AutodeskExpertElite #Revit #Rollback
Donnia Tabor-Hanson, aka CADMama
Revit Family Counselor
Revit CSI
Revit Forensic
Twitter @DonniaTH
