Thoughts...
Aero theme OFF?
Install .NET FRAMEWORK 4 BETA?
Overclocking Processor? If so, OFF?
Video as Direct3D?
All SP/Patches for Revit?
~Terry
eviele wrote:
> Hello fellow CAD Manglers. I have a question or two. Hopefully you can help us diagnose something.
> We're rolling out Win 7 64bit machines and have included Revit 2009 for those folks still finishing projects on that version.
> Our IT guy has hit a stumbling block.
> One person in the office has gone through three rebuilt machines in a day. Each time that user goes to open the team's Revit file he gets an error that says Revit has suffered an unrecoverable error and will close.
> Everyone else on the team can open and work on the file just fine.
> All users are the same build (Revit I mean - build 1045).
> The kicker was the third machine. The IT guy built it using our ghost software, tested it every step of the way including opening the team's central file, then he carries the machine over to the user, plugs it in and gets a blue screen of death. Starts the machine up again, crosses his fingers, and all seems well, until the user opens the team central file and crashes. So it worked during all of the testing and failed when brought over to the user. The only apparent difference is that the user is running two monitors and the IT person thinks that may have been the cause of the crash, but he's not sure why Revit won't open the team file now.
> So three different computers upgraded with new RAM for each and they all fail.
> This seems endemic to our Win 7 process. We had another user that the IT guy built three machines for with the third one finally working. Same kinda issue, the user couldn't open the central file of a revit project.
> So far, about 15 machines have been built and of those about 5 have had weird problems and have been replaced.
> What are the machines?
> XI's. They were expensive, but reliable and fast and built for us by the folks over at XI. Now our IT guy is blowing away XP and doing a fresh install of Win 7 and adding RAM. Well, the ghost image was made from a fresh install. All machines we hand out are made from the ghost image.
> Can you not create a ghost image of Revit?
> Will installing Revit manually save us?
> (sorry, that just occured to me - I'd ask the IT guy to test it, but he's done with this issue for the day)
> The revit file is kinda big, 190MB, but it's manageable. I can open it here on my copy of Win 7 and the rest of the team can work with it so I don't think it's the file.
> So what might it be?
> Any ideas?
> Thanks in advance...
