Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
MAPCSLIBRARY Errors and Omissions
Pointdump
Consultant Consultant
Message 1 of 57
Pointdump
This is an attempt to list errors and omissions in MAPCSLIBRARY.
The Tern Island 1961 Datum, Code: Tern61, shows an EPSG Code of 6707. It should be >>>EPSG:4707<<<. The EPSG site erroneously also lists the Tern Island 1961 Datum as >>>EPSG:6707-datum<<<, so it's not completely Autodesk's fault. EPSG:6707 should be >>>RDN2008 / UTM zone 32N (N-E)<<<.
To be honest, I don't understand the distinction between a Datum and a GCS(Geographic Coordinate System) in MAPCSLIBRARY. Feel free to school me.
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Replies (56)
Message 2 of 57
Pointdump
>>>EPSG:3964, MGI 1901 to WGS 84 (4)<<< shows the 7-Parameter Geodetic Transformation as (551.7, 162.9, 467.9, 6.04, 1.96, -11.38, -4.82)
MGI-1901_to_WGS84 in MAPCSLIBRARY has the signs reversed on Axis Rotation of Arc (seconds):(551.7, 162.9, 467.9, -6.04, -1.96, 11.38, -4.82)
Dave Stoll
Las Vegas, Nevada
Message 3 of 57
Pointdump
MAPCSLIBRARY shows the CocosIsl1965 Datum(Cocos Island 1965) as EPSG:6708.
>>>EPSG:6708<<< is really RDN2008 / UTM zone 33N (N-E), which is not in MAPCSLIBRARY.
Dave Stoll
Las Vegas, Nevada
Message 4 of 57
Pointdump
MAPCSLIBRARY shows the IwoJima45 Datum(Iwo Jima 1945) as EPSG:6709.
>>>EPSG:6709<<< is really RDN2008 / UTM zone 34N (N-E) which is not in MAPCSLIBRARY.
Dave Stoll
Las Vegas, Nevada
Message 5 of 57
ChicagoLooper
EPSG 4709?
Chicagolooper
Message 6 of 57
ChicagoLooper
The RDN's for zones 32, 33 and 34 are not in the MAPCSLIBRARY.
Search EPSG 6709 in Global Mapper and you'll get this:
Image-101.Image-101.
EPSG 6709, when exported from global Mapper, look like this.
Image-102.Image-102.
Search zone 34 in Map3D and you'll get this:
Image-201.Image-201.
If you 'view' the projection for EU-34 and you'll see this.
Image-202.Image-202.
You have uncovered errors. Autodesk needs to add or update RDN 2008 (Rete Dinamica Nazionale 2008). In the absence of an update,  ADSK can provide a link to download the RDN's in order to add them to the MAPCSLIBRARY.
@Pointdump  you are thee CSI, Coordinate System Investigator 😀.
Chicagolooper
Message 7 of 57
Pointdump
A request for >>>ESRI:102766 NAD 1983 StatePlane Guam FIPS 5400 Feet<<< from >>>This Thread<<<.
Dave Stoll
Las Vegas, Nevada
Message 8 of 57
Pointdump
Two more that are missing:
EPSG:29700, "Tananarive (Paris) / Laborde Grid",
EPSG:29702, "Tananarive (Paris) / Laborde Grid approximation"
Dave Stoll
Las Vegas, Nevada
Message 9 of 57
TerryDotson
Another one that's missing:
EPSG:7415 Amersfoort / RD New + NAP Height
At a glance, it appears that all the downloadable Lidar from this site ...
https://geotiles.nl/
... is in this coordinate system.
Message 10 of 57
Pointdump
TMBLI-B.RSOBorneo.m, Timbalai 1948 / R.S.O. Borneo (m), EPSG:29873, MAPCSLIBRARY lists a Rectified Skew Orthomorphic Projection. But >>>EPSG:29873<<< is a Variant B, so it should be Rectified Skew Orthomorphic, origin at center. Further, the Azimuth and Rectified Grid Angle are different, and there is no way to define that difference in MAPCSLIBRARY.
Dave Stoll
Las Vegas, Nevada
Message 11 of 57
I bet you can't wait for the North American-Pacific Geopotential Datum of 2022 (NAPGD2022)
lets just start every project at 5000, 5000 and call it good.
Message 12 of 57
Pointdump
Hi David,
"I bet you can't wait for the North American-Pacific Geopotential Datum of 2022"
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 57
Pointdump
"NSRS is the official reference system for latitude, longitude, height, scale, gravity, and orientat...
NSRS is not a Datum, so "NSRS07" and "NSRS11" should instead be "NAD83_2007" and "NAD83_2011".
All the State Plane Coordinate Systems that use the 2007 and 2011 realizations of NAD83 should not use the initials NSRS in any part of their definition.
Dave Stoll
Las Vegas, Nevada
Message 14 of 57
Pointdump
As far as I know, Map 3D only uses Geographic and Projected Coordinate Systems. Satellites use Earth Centered, Earth Fixed Coordinates. Most GPS devices are able to convert that XYZ to Latitudes and Longitudes. I don't know if it's possible to add an Earth Centered, Earth Fixed Coordinate System like >>>EPSG:4896<<< to MAPCSLIBRARY, but there are requests like the one >>>Here<<<.
Dave Stoll
Las Vegas, Nevada
Message 15 of 57
jetdog6
I second Pointdump's post, the "NSRS11" is confusing, it should be "NAD83(2011)" for example, or some iteration of that. Infact, I don't know why they don't just use EPSG codes. That's a well known standard that would clear up alot of confusion.
Message 16 of 57
jetdog6
@Pointdump suggested I post my description of a coordinate system problem here:
"Autocad C3D claims that coordinate system codes NVHP-WF and HARN/NV.NV-WF are interchangeable, and the same as EPSG3431.  However, this does not appear to be true.  If I set my coordinate system to HARN/NV.NV-WF, export some points using the FGDB export function, and import that GDB database into global mapper, global mapper shows the GDB actually has it's datum set to WGS84, not NAD83.  If I set my coordinate system to NVHP-WF, export some points using the FGDB export function, and import that GDB database into global mapper, global mapper shows the GDB has the correct datum of NAD83 (NEVADA HPGN) - NADCON.  The two GDB databases referenced above, if both brought into global mapper, result in a shift of over a foot!  Needless to say this is a big deal.  NVHP-WF and HARN/NV.NV-WF are definitely not the same, and HARN/NV.NV-WF is definitely not EPSG3431."
Message 17 of 57
Pointdump
Using MAPEXPORT in a drawing with the MAL-MRSO Coordinate System, Map won't include a PRJ file. >>>Thread Here<<<.
AKN article >>>Here<<< notes Coordinate Systems not supported when exchanging data with ArcGIS, but there's a bigger problem. The MAL-MRSO Coordinate System (>>>EPSG:3168<<<) has both an Azimuth Parameter and a Rectified Grid Angle Parameter. MAPCSLIBRARY doesn't seem to be able to include both in a Rectified Skew Orthomorphic projection definition. So Map throws up its hands when asked to supply a PRJ file.
Dave Stoll
Las Vegas, Nevada
Message 18 of 57
Pointdump
Omission: >>>EPSG:3031<<< WGS 84 / Antarctic Polar Stereographic
Dave Stoll
Las Vegas, Nevada
Message 19 of 57
Pointdump
Add >>>EPSG:6350 NAD83(2011)/Conus Albers<<< to MAPCSLIBRARY. USGS uses that Coordinate System on Point Clouds for public download, like >>>This<<<. Others inquiring >>>Here<<< and >>>Here<<<.
Dave Stoll
Las Vegas, Nevada
Message 20 of 57
Pointdump
The ELD1979_to_WGS84 Geodetic Transformation uses a Geocentric Translation of TOWGS84[-69.06,-90.71,-142.56,0,0,0,0]. EPSG:1859 ELD79_to_WGS84(1) uses that shift. But there are other European Libyan Datum 1979 shifts that should be included. Most of the projected Libyan coordinate systems use EPSG:15909.
EPSG:1859 ELD79_to_WGS84(1): TOWGS84[-69.06,-90.71,-142.56,0,0,0,0]
EPSG:1860 ELD79_to_WGS84(2): TOWGS84[-113.997,-97.076,152.312,0.0,0.0,0.0,0.0]
EPSG:1861 ELD79_to_WGS84(3): TOWGS84[-114.5,-96.1,-151.9,0,0,0,0]
EPSG:1862 ELD79_to_WGS84(4): TOWGS84[-194.513,-63.978,-25.759,-3.4027,3.756,-3.352,-0.9175]
EPSG:1863 ELD79_to_WGS84(5): TOWGS84[-389.691,64.502,210.209,-0.086,-14.314,6.39,0.9264]
EPSG:15707 ELD79_to_WGS84(6): TOWGS84[-118.996,-111.177,-198.687,0.0,0.0,0.0,0.0]
EPSG:15778 ELD79_to_WGS84(7): TOWGS84[-114.7,-98.5,-150.7,0.0,0.0,0.0,0.0]
EPSG:15909 ELD79_to_WGS84(8): TOWGS84[-115.8543,-99.0583,-152.4616,0.0,0.0,0.0,0.0]
EPSG:15923 ELD79_to_WGS84(9): TOWGS84[-117.7,-100.3,-152.4,0.0,0.0,0.0,0.0]
Dave Stoll
Las Vegas, Nevada
