Need Help with Coordinate System
nrogers58
Message 1 of 24
nrogers58
I am using point clouds and from the meta data, the best I can tell about the coordinate system is
NAD_1983_2011_Contiguous_USA_Albers",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM
I am having trouble selecting the appropriate current coordinate system using Recap such that when I bring the point cloud into Civil 3D it is properly georeferenced.
Please Help!
Neal
Replies (23)
Message 2 of 24
Pointdump
Hi Neal,
Please post a link to where you got the clouds.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 24
nrogers58
Message 4 of 24
Pointdump
Neal,
A while back I created the 2011NAD83/ConusAlbers(EPSG:6350) Coordinate System in Map 3D. I've attached it. Use Command MAPCSLIBRARYIMPORT to add it to your MAPCSLIBRARY in Civil 3D or Map 3D. I've also filtered Ground(2) Points and used ReCap to Transform the Point Cloud from 2011NAD83/ConusAlbers to NAD83/Florida North(ftUS).
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 24
nrogers58
Thanks.
Does not appear that the point cloud captures the project site. No worries.
Question how do add coordinate system you made to recap?
Neal
Message 6 of 24
Pointdump
Neal,
You'll add that Coordinate System to MAPCSLIBRARY in Civil 3D or Map 3D. Use Command MAPCSLIBRARYIMPORT. ReCap uses the Coordinate System Library from Map 3D.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 24
nrogers58
MAPCSLIBRARYIMPORT failed to import the xml file.
Thanks for trying.
Neal
Message 8 of 24
Pointdump
Neal,
After using MAPCSLIBRARYIMPORT, Close and Save your Drawing, then Exit >> Re-Start Civil 3D. It should be there now.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 24
nrogers58
Worked like a champ!
Thank you so much!
You have no idea how long I have worked on this one.
Thanks Again
Neal
Message 10 of 24
jonrQ9Y9P
Community Visitor
Community Visitor
Dave, I was having the same problem.  Thankfully, your thread showed up in google search and yes, it worked like a champ!.  I have no idea how you made this coordinate system and don't want to b/c it would blow my brain trying to figure it out.  That said, I am very thankful you shared it.  I really appreciate you.
Jon
Message 11 of 24
whiskytown
Thanks for your reply today to my similar EPSG 6350 problem.  Now I found your file above, but it failed to import to the library altogether. (I closed and rechecked, just to make sure).
Message 12 of 24
whiskytown
Yay! The custom CS (homebrew EPSG 6350) did finally appear in both C3D and Recap!
Message 13 of 24
cmhoot
How could I use this coordinate system to import a DEM file?  When trying to apply a CS code, I cannot seem to locate the imported system as an option even though I can find in my library.  It doesn't seem to have a category, so maybe that is part of the problem.
I want my coordinate system to be in state plane, but I'm trying to bring in USGS data.
Message 14 of 24
Pointdump
Hi Christine,
A link please to your data.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 24
cmhoot
Message 16 of 24
Pointdump
Christine,
Thanks for posting your link.
Metadata at your link shows, and drag-n-dropping the tiff into QGIS verifies, it's in the geographic coordinate system >>>EPSG:4269 NAD83<<<.
"<geodetic>
    <horizdn>North American Datum of 1983</horizdn>
<altsys>
    <altdatum>North American Vertical Datum of 1988</altdatum>
    <altunits>meters</altunits>"
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 24
cmhoot
Sorry, that was the wrong link (although I will need to convert that one as well).  Try this one: USGS Lidar Point Cloud MS_Central_Delta_2018_D18 e0554n1242 - ScienceBase-Catalog
Message 18 of 24
Pointdump
Wow, it's huge! 117 million points! That's gonna take a while to load, and will bog down C3D. I'd suggest you use a data clip boundary before import, or crop the tif to your area of interest using QGIS or similar software.
Dave
Dave Stoll
Las Vegas, Nevada
Message 19 of 24
cmhoot
A data clip boundary is definitely the goal, but I have to be able to import it into the right spot first.  Any guesses on the coordinate system setting?
Also, I just realized that was the lidar point cloud of the right location, which would be brought in a completely different way.  Here's the tif associated with that area: https://www.sciencebase.gov/catalog/item/6391d255d34e0de3a1efcc00
Message 20 of 24
Pointdump
Christine,
The LiDAR point cloud data is best. A tif DTM is a derivative product. In ReCap you can transform the 2011NAD83/ConusAlbers laz into IN83-EF. You'll also want to filter ground (2) points:
histogram of classification of points:
5356375 unclassified (1)
3556317 ground (2)
1317 noise (7)
847 bridge deck (17)
118 Reserved for ASPRS Definition (18)
And you'll definitely want to crop that cloud to under 2 million points before using it in C3D.
Dave
Dave Stoll
Las Vegas, Nevada
