Decap automation C#
Decap automation C#
jens.slofstra!
Decap automation C#
jens.slofstra!
Hi everyone,
I was wondering if decap automation is possible with C#.
I found a python script that works but I want to use the script in an revit addin which is in C#.
Python code below:
<location>/decap.exe –importWithLicence E:\decap text\Building 1\ Building 1
Can somebody get me in the right direction.
Anyway thanks 🙂
jens.slofstra!
After some more searching I found a work around. DeCap runs via the command prompt. So I open command prompt with C# and then run the command for DeCap.
Preview below:
//Process Info
                var cmdInfo = new ProcessStartInfo
                    RedirectStandardInput = true,
                    RedirectStandardOutput = true,
                    RedirectStandardError = true,
                    UseShellExecute = false,
                    FileName = "cmd.exe",
                //Process
                var cmd = new Process();
                cmd.StartInfo = cmdInfo;
                cmd.Start();
                var outStream = cmd.StandardOutput;
                var inStream = cmd.StandardInput;
                //Command Line for DeCap
                inStream.WriteLine("cd C:\\Program Files\\Autodesk\\Autodesk Recap");
                var run = true;
                var cmdTask = Task.Run(() =>
                        while (run)
                            try
                                Console.WriteLine(outstream.ReadLine());
                            catch { }
                            Thread.Sleep(20);
                            if (outStream.ReadLine().Contains("[R]"))
                                _logger.LogInformation(@"File Converted: {0}\{1}", _LAZProcessed, LAZFile.Name);
                                run = false;
                inStream.WriteLine("{0}decap.exe{0} --importWithLicense {0}{1}{0} {0}{2}{0} {0}{3}{0}", '"', _LAZProcessed, LAZFile.Name, LAZFile.FullName);
                while (!cmdTask.IsCompleted)
                    Thread.Sleep(1000);
