AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Running Autocad Lt on Windows XP
12 REPLIES 12
Message 1 of 13
1764 Views, 12 Replies
Hi all,
This is my first post......
I own and run a small joinery company, just me, in the UK.
I use Autocad Lt 2016 on a windows 10 computer for my main office tasks, producing drawings for customers and then using the drawings to manufacture the products.
However, in 2001 i purchased a AXYZ Millenium CNC Router which is still a valuable piece of workshop kit for manufacturing my products. The CNC software will only run windows XP and no higher on a PC in my workshop, both workshop and office PC's use my Nas Drive as a mapped drive so no files on any PC,s and both need Autocad Lt installed.
Having just purchased a stand alone license i would like to install Autocad Lt 2013 as my second download on the windows XP PC in the workshop, any advice on doing this would be welcome.
Steve.
12 REPLIES 12
Message 2 of 13
pendean
XP is a dead OS and LT2013 is retired with no chance available for you to 'get it' sadly.
There are many ways Microsoft makes Win10 capable of running most XP software, you might try these options first. Explore the topic in these thread here https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=run%20xp%20software%20o...
Message 3 of 13
steven-g
Don't you still have an older version of Autocad licence on the xp computer, (as far as I know buying a newer version doesn't stop you using the old one - unless it's an update!!), how have you been running the cnc before? I would keep the old version just for the cnc and save any new drawings created in 2016 version back to a format that can be read in the old software.
Message 4 of 13
TravisNave
in reply to: steven-g
AutoCAD LT 2013 is still available on the Virtual Agent if you need to download it, but Dean is right about XP being retired.  You should still be able to run AutoCAD LT 2013 on a Windows 7 machine though.  AutoCAD 2016 still uses the DWG 2013 format, so compatibilty should not be an issue there.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 13
pendean
in reply to: TravisNave
I wondered if the OP has a license for LT2013 or not: if yes, they will be able to take advantae of your tip fully.
Message 6 of 13
TravisNave
in reply to: pendean
True boss.  It's not exactly something one would be able to just get their hands on without already owning it or having Subscription.  But even Subscription doesn't allow concurrent use on a 2nd computer if there is only 1 seat.  Hmm...
Autodesk Forums:
Message 7 of 13
Thanks for your reply, i have a maintenance subscription with my recently purchased Autocad Lt, does this not allow me to install a second older version (2013) on another machine and also if i wanted too, apply for a home use download as well?
Steve.
Message 8 of 13
TravisNave
Subscription allows you to install 2013 so long as you do not use it concurrently (simultaneously) with your 2016. But you can alternate between them or use one on your laptop or home, for example.
Autodesk Forums:
Message 9 of 13
Thanks again, so can i install it on the XP machine, it has the system requirements needed. Idealy i would like to download the software using the windows 10 PC and then install it on the XP (workshop PC).
Would i be able to download and save it to my Nas Drive ready to install on the XP machine?
Steve.
Message 10 of 13
TravisNave
I don't see why not. I would then recommend copying the install file from
the NAS to the local machine.
Autodesk Forums:
Message 11 of 13
So using the Virtual Agent method i would be able to save it straight to the Nas Drive?
Steve.
Message 12 of 13
TravisNave
Yes. The install file can be saved anywhere but you will still want to copy
and install it on the local machine.
Autodesk Forums:
Message 13 of 13
Many Thanks for your help, i will give it a go in the next couple of days.
Thank you also to the other replys for your help and advice.
Steve.
Technology Administrators
