Welcome to the Forums
As long as your PC is the only other computer it's installed on and you don't use both your laptop and PC at the same time I do believe it's ok to install it as normal
Howard Walker
The only caveat is if you are using the educational version -- as it is limited to one install.
@Anonymous,
Here are some help links if you need them to reference to aid you in downloading AutoCAD on your Laptop along with the Activation FAQ.
Hi @Anonymous,
Following up on this thread, I haven't heard back from you in a few days.
Post back in the thread if you have any other questions you may need help/support on. Please select Accept as Solution if my post or any other post in this thread answered your question.
Thanks.
