Unhandled Exception c0000005 (Access Violation Reading 0xf9fdffff) at address
I am continously getting this error at startup and when I try to do a command. It says "Unhandled Exception c0000005 (Access Violation Reading 0xf9fdffff) at address 30bbcd83h". I'm using AutoCAD 2017 and Windows 7.
http://i.imgur.com/WiZCKeG.png
http://i.imgur.com/8dLuwbU.png
http://i.imgur.com/wAuQo0h.png
http://i.imgur.com/b7TB7fT.png
http://i.imgur.com/GzcKKa4.png
http://i.imgur.com/ezLnB1s.png
And then it will say "Unknown command. Press F1 for Help."
Alfred.NESWADBA
welcome @forums.autodesk.com!
Try to reset the AutoCAD profile as described >>>here<<<.
If that does not help, try to login with another Windows user account having admin permissions, turn off antivirus and then start AutoCAD again
If both does not work run a repair installation of AutoCAD (>>>how to<<<).
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
TravisNave
I agree with Alfred.
Also note that these kinds of errors can be caused by a problem with .NET Framework and/or a virus or malware infection on your computer.  Definitely try the steps above -- especially logging in as another local administrator user.  Create a temp one if you have to.
If that doesn't work and a spyware scan comes up negative, consider also reparing your .NET Framework.  .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Error 2. Happened when I reset the AutoCAD profile
http://imgur.com/a/s5udk
Error 3: Happened when opening AutoCAD in another admin account and disabled all antivirus.
http://imgur.com/a/1q3d6
Error 4: Happened when I put the antivirus back on.
http://imgur.com/a/ZRlql
Error 5. Happened when I did the Repair Installation.
https://i.imgur.com/CDbGFkC.png
Alfred.NESWADBA
well documented, great!
The last error with acvmtools looks like issues with the graphic card driver.
Which graphic card and which driver do you have installed?
- alfred -
Alfred NESWADBA
Here is graphics card and driver:
http://i.imgur.com/llQwq2B.png
The issue seems to be resolved. I guess all I needed to do was reinstall my graphics driver. Thanks for letting me know it was an issue with the graphics driver.
