two version in one computer
Message 1 of 9
is it possible to install autocad 2016 and autocad 2018 in same  computer please tell me guys ??
Replies (8)
Message 2 of 9
Slawomir_
Yes it's possible.
Message 3 of 9
kadmonkee
it is possible
keep in mind it may cause Licensing issues if you have limited seats
each version uses a seat if you are on a license server
also the backward compatibility may become an issue for other users who do not have 2018
xreference files will be saved  in the later version.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 4 of 9
TravisNave
Make sure you install 2016 first.  Though, there really isn't a need to have both versions installed.  You can save back to the 2013 DWG file from 2018 for any 2016 users.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 9
john.vellek
Hi @Anonymous,
Yes, different versions of AutoCAD can coexist on a single computer. It is best practice to install and update the older version(s) first.
AutoCAD 2013-2017 all support drawing version 2013 (and older ones) while AutoCAD 2018 supports a new 2018 drawing file format.
If you are on subscription, you are entitled to the current (2018) version as well as the two prior versions.
John Vellek
Message 6 of 9
braudpat
Hello
+1 with other Technical virtual Friends and/or EEs !
On my PCs I have about :
5/6/7 versions of ACAD MAP 201X
2/3/4 versions of ACAD 201X
2/3 versions of ACAD CIVIL 201X
2/3 versions of ACAD LT 201X
2/3 versions of ACAD Archi (or ACAD MEP) 201X)
And almost NO Problem ! ... Of course all versions has been installed in the "right" order ...
Happy WE, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 7 of 9
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 8 of 9
I am hoping you might be able to answer a similar question for me. I recently downloaded a trial version of AutoCAD 2020, and it also downloaded fusion360. I have an older version of Fusion 360 on my computer. I cannot work in either version without it constantly crashing and freezing. should I remove one version? and can I do this without losing my autocad trial?
thanks for any and all help.
Message 9 of 9
RobDraw
Your question would be better off asked over here:
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Rob
