Geolocation map not get after updation
Dear Sir,
I have using geolocation map, but it is giving error for update. After install update it is given repeatedly same notification for update. Please guide us how to resolve this problem.
Bhavyajitsinh
liuyun_sg
Bhavyajitsinh,
What version of your product? Can you run _VERNUM in command line?
Can you do a screen capture of the problem?
Regards
Liu
Autodesk Inc
Yun Liu
Principal Software Engineer
JianStewart
Thanks for your report.
I am not sure which version you are using. Could you attach a capture to show which information you met and your product version?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Stewart Li
Senior QA of AutoCAD
We have AutoCAD LT 2014 version and please find error message when we are try to using geolocation map..for your reference please..
we have using AutoCAD LT 2014 version. Please find error snap for your reference
JianStewart
Unfortunately current AutoCAD 2014 and AutoCAD LT 2014 have been discontinued on Online map support.
You may refer to this article, you need to update your productSmiley Tongue
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Geolocat...
Stewart Li
