Problem with reference
C.Utzinger
C.Utzinger
Hi
Everytime I Close my drawing and open it again, the attached reference is missing. It shows like not found.
I have no idea why. I have reloaded it 50 times.
I work with AutoCAD 2017.
Please help.
ennujozlagam
@C.Utzinger hello, have you tried to use full path and attachment when you xref a dwg file. thanks
C.Utzinger
HI
I have it like this always, and ervey reference works fine, ist only this one.
I tried for example to copy the drawing in another dwg witch works fine, after that happens the same with this one.
So i think there is a Problem with this drawing :(...
Thank you
ennujozlagam
@C.Utzinger hello, please see attached. manage to solved your issue. i dxfout your drawing and dxfin > save > open new drawing > attached as xref no issue. thanks.
C.Utzinger
Thank now it works!!!
ennujozlagam
@C.Utzingerhello, no worries, glad to help. thanks
