How old is your computer?
Might check this link:
http://usa.autodesk.com/getdoc/id=TS13641549
Thank you very much for the prompt reply!
I bought my PC in early 2004; maybe that is the problem.
The CPU is an Athlon XP 266FSB. I did a little research on the web, but cannot tell if this CPU supports the "SSE2 instruction set" as described by Autodesk.
Ah, yes that appears to be your issue as that AMD does not support the SSE2. You will need to reinstall the software on a newer PC.
you can use this tool to determine if you have sse2: http://www.cpuid.com/softwares/cpu-z.html
DarrenP
