Installation & Licensing
LM on Instructors Station
2 REPLIES 2
260 Views, 2 Replies
Can we use the Instructor Station which needs to run AutoCad as the license manager as well?
2 REPLIES 2
hashim.mundol
Yes as long as the system requirement matches this
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_Installation_and_Licensing/0000-Revit_In0/008...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
TravisNave
Yes, it will work fine.  If the instructor station is Windows Vista, Windows 7, or Server 2008, you might have an IPv6 issue.  That can be easily resolved by modifying the LICPATH.LIC file to include 127.0.0.1 instead of the hostname.  Or you can try my other methods below.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
