Installation & Licensing
Autocad 2013 Silent Install
1 REPLY 1
2730 Views, 1 Reply
i  want to deploy Autocad 2013 with a Batchfile.
my command looks like this:
start /wait setup.exe /w /t /qb /language de-DE /c ACAD: INSTALLDIR="%ProgramFiles%\Autodesk\AutoCAD 2013" ACADSERIALPREFIX=000 ACADSERIALNUMBER=00000000 ADLM_PRODKEY=ABCDE ADLM_EULA_COUNTRY=DE InstallLevel=5
I am always getting an error to enter a vaild Serial Number. What i found out in that support forum is to use the zero´s for installation in Trial mode. that is what i need because the User needs to put in the serial Number.
Has anyone an ideo on that on. What is wrong with that command line?
rgds
Sebastian
1 REPLY 1
TravisNave
Any particular reason you don't want to simply deploy it with a precreated deployment and save yourself the hassle?
Autodesk Forums:
Administrator Productivity
