Please try the uninstaller script
http://usa.autodesk.com/getdoc/id=TS16077500
If this doesnt help, we will need to clean up the registry entry from the installer hive or use a 3rd party clean up utility.
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
I have cheched it, but it shows errot- 2147467259- configure product and also AcadLP.msi cannot be uninstalled unless Acad.msi has been uninstalled.
Sanoop
is there an error message?
DarrenP
@Anonymous wrote:
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me.
Is there a reason you responded to a solved post that is more than 2 years old here in this forum? We appreciate all sorts of help here, but please try to help users with current issues if you wish to participate and add value to the forum. Thanks!
