Inventor Forum
Hotfix Kb971138 Download for Vista
60 REPLIES 60
Message 1 of 61
23828 Views, 60 Replies
Morning,
I received  Autodesk Product Design Suite Premium 2012. I'm trying to install and it's saying that I need Hotfix KB971138 for Vista. I can't seem to locate the download link. I found a page that autodesk directs you too, but there's no Link that I can find. Has anyone been through this and found the fix?
System
Core i7 950 @ 4ghz
Asus P6T X58
Corsair Dom 6gig 1600mhz
Evga Gtx 260
Win Vista 64bit Ult
60 REPLIES 60
Message 41 of 61
i also need the same hotfix. Got the download.
But where should i need to unzip the downloaded file?
Message 42 of 61
DarrenP
you can extract anywhere
DarrenP
Message 43 of 61
in reply to: DarrenP
oops indeed now i found out it is a self installer sorry
Message 44 of 61
Hi guys, I was able to install and extract the hotfix. But when I run the fix it says "Not applicable to your system" I have the Vista SP2 so I'm not sure whats wrong...... Any help?
Message 45 of 61
You may have a 64bit version of Windows and are trying to install a 32bit patch or the other way around. Right click on "computer" and hit properties. It will show you what version you have there. Hope this helps.
Message 46 of 61
Message 47 of 61
DarrenP
you may also want to ask microsoft support since this is a windows hotfix not an autodesk hotfix
DarrenP
Message 48 of 61
where is a link to download the 32 bit vista hotfix kb971138????
Message 49 of 61
TravisNave
I have provided this in an earlier post in this thread.  You can download the 32-bit one here:
http://forums.autodesk.com/t5/Installation-Licensing/Email-with-hotfix-for-inventor-has-no-password/...
Autodesk Forums:
Message 50 of 61
DarrenP
in reply to: TravisNave
is this hotfix that hard to find?
DarrenP
Message 51 of 61
TravisNave
Preaching to the choir, my friend.  Smiley Very Happy
Autodesk Forums:
Message 52 of 61
Hello guys! I need the KB971138 and when i try to donwload it using the link that microsoft send me in the email (hotfix@microsoft.com) II get the following message:
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
And I can´t download it
Can you send me a valid link to download the file?
Thanks!! And sorry for my bad english, i´m from Spain Smiley Frustrated
Message 53 of 61
DarrenP
why are you posting here?
this isn't the microsoft support forum
DarrenP
Message 54 of 61
Sorry, I don´t understand you. Because you say that?
Message 55 of 61
TravisNave
Sometimes I wonder how many times I will have to repost this...
*sigh*
Autodesk Forums:
Message 56 of 61
HOw you did it!? I have the exact same problem, please if you could tell me it would be great, or better if you could email me the answer at luisfer.a.e@gmail.com
Thank you 🙂
Message 57 of 61
Hey Nick, i'm having thesame problem,  i went to thesame link but didn't see the Hotfix Kb971138 Download for Vista as informed. How did you find the Hotfix Kb971138?
Message 58 of 61
how did you get the Hotfix?
Message 59 of 61
TravisNave
Once again... the hotfix (sans password) is attached to my message here:
Please download it.
Autodesk Forums:
Message 60 of 61
I am having this same problem with Windows Vista 64 bit version. I go to unzip the files that Microsoft has sent me through an email. When it goes to unzip the files it comes up with an error code of 40. All help will be appreciated
