Installation & Licensing
Why can't I Install NLM on a Parallels VM?
4 REPLIES 4
332 Views, 4 Replies
I have tried numerous times and I cannot get it to work. I have hard coded the MAC address and given it a static IP, but nothing seems to let me install it.
I constantly get the error: You Cannot Install This Product on the Current Operating System
I have tried this on Windows XP Pro, Windows XP Home, as well as Windows Server 2003........any thoughts or ideas why this does not work?
Any help would be much appreciated. Edited by: avltCAD on Aug 18, 2009 4:24 PM
4 REPLIES 4
TravisNave
Sounds like a problem with the installer. The NLM doesn't need to be installed, however. Just copy the 4 .exe files to the hard drive. I have posted the link and provided the adskflex.exe in an earlier post.
http://discussion.autodesk.com/forums/thread.jspa?threadID=737291&tstart=0
Autodesk Forums:
I figured it out........thanks for the help y'all!!!!
TravisNave
Glad you are up and running. If your fix was different than my suggestion above, you should post your solution for others who might have a similar problem in the future. 🙂
Autodesk Forums:
OK....make sure you are using the current and correct installer!!!
Administrator Productivity
