How can I get visualization of revit file on tablet Windows surface Pro 128 Gb, I' ve installated revit 2014 but doesn't start, in other way autocad 2014 get right!
Solved by ppesce. Go to Solution.
I don't understand your problem. Autodesk products work fine on my Surface Pro. What issue are you experiencing?
I've Building Design Suite Premium and Revit 2014 on windows 8 tablet surface pro but revit doesn't work, i send you a error file
And that translates to?
Hello. If you could translate into English, it may help. I am guessing there may be a corrupt install or a permission problem. Have you uninstalled and reinstalled?
Have you updated your graphics card drivers?
Have you checked the Windows Event Log for any errors?
I would uninstall and trr to reinstall first, and make sure Antivirus is off before you install. It is a good place to start.
Thank you for taking part in our community!
i send the translation:
Impossible to start the specified application. The configuration of the flanked mode application is not right. To consumption event registry application or use tool line command sxstrace.exe to have more information
This is a known problem with the Visual C++ files.
Please see this KB article:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095878&linkID=9241177
Good Luck!
I've solved unistalling all autodesk programs and reinstalling with the right Visual C + + files,
thank for your support
