I've tried to install Revit a few times now, and after a long process it fails in the end. I am getting this:
2013/3/1:19:32:39 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:32:39 Andrew ANDREW-HP Launch 2013/3/1:19:32:43 Andrew ANDREW-HP [Error: 1056] An instance of the service is already running. 2013/3/1:19:32:43 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:32:38 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:32:38 Andrew ANDREW-HP Launch 2013/3/1:19:32:38 Andrew ANDREW-HP CommandLine 2013/3/1:19:32:43 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:43:17 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:43:17 Andrew ANDREW-HP Launch 2013/3/1:19:43:17 Andrew ANDREW-HP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-35525242 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/3/1:19:51:23 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:43:19 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:43:19 Andrew ANDREW-HP Launch 2013/3/1:19:46:47 Andrew ANDREW-HP Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:19:51:23 Andrew ANDREW-HP Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:19:51:23 Andrew ANDREW-HP PageOpen LaunchDialog 2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen LicenseDialog 2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen ProductInfoDialog 2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen ProductSelectionDialog2 2013/3/1:19:56:55 Andrew ANDREW-HP PageOpen FullProgressDialog 2013/3/1:19:56:56 Andrew ANDREW-HP Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:58:22 Andrew ANDREW-HP Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:58:22 Andrew ANDREW-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2013/3/1:19:58:37 Andrew ANDREW-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/3/1:19:58:39 Andrew ANDREW-HP Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:59:45 Andrew ANDREW-HP Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:59:45 Andrew ANDREW-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2013/3/1:19:59:57 Andrew ANDREW-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/3/1:19:59:57 Andrew ANDREW-HP Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:19:59:58 Andrew ANDREW-HP Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:19:59:58 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:00:03 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2013/3/1:20:00:03 Andrew ANDREW-HP Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:09 Andrew ANDREW-HP Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:09 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:02:16 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2013/3/1:20:02:17 Andrew ANDREW-HP Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:32 Andrew ANDREW-HP Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:32 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:02:38 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2013/3/1:20:02:38 Andrew ANDREW-HP Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:40 Andrew ANDREW-HP Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:40 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:02:45 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2013/3/1:20:02:46 Andrew ANDREW-HP Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:47 Andrew ANDREW-HP Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:47 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:02:50 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2013/3/1:20:02:50 Andrew ANDREW-HP Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:04:50 Andrew ANDREW-HP Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:04:50 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:04:57 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2013/3/1:20:04:57 Andrew ANDREW-HP Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:13 Andrew ANDREW-HP Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:13 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:05:19 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2013/3/1:20:05:20 Andrew ANDREW-HP Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:21 Andrew ANDREW-HP Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:21 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:20:05:26 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2013/3/1:20:05:26 Andrew ANDREW-HP Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:06:12 Andrew ANDREW-HP Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:06:12 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/3/1:20:06:34 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2013/3/1:20:06:34 Andrew ANDREW-HP Download Play VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:07:20 Andrew ANDREW-HP Download Complete VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:07:20 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/3/1:20:07:37 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded 2013/3/1:20:07:37 Andrew ANDREW-HP Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:55 Andrew ANDREW-HP Download Error DIRECTX <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:56 Andrew ANDREW-HP Download Aborted DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:56 Andrew ANDREW-HP Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:15:56 Andrew ANDREW-HP Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Download Error FaroSDK <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Download Aborted FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Install FaroSDK Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:17:27 Andrew ANDREW-HP Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:54 Andrew ANDREW-HP Download Error RVT2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:55 Andrew ANDREW-HP Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:55 Andrew ANDREW-HP Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:37:56 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2013/3/1:20:37:56 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2013/3/1:20:37:59 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2013/3/1:20:38:02 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2013/3/1:20:38:05 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2013/3/1:20:38:07 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2013/3/1:20:38:10 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2013/3/1:20:38:13 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2013/3/1:20:38:16 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2013/3/1:20:38:18 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2013/3/1:20:38:18 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/3/1:20:38:19 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/1:20:38:19 Andrew ANDREW-HP PageOpen InstallCompleteDialog 2013/3/1:21:00:07 Andrew ANDREW-HP === Setup ended ===
2013/3/1:21:11:29 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:21:11:29 Andrew ANDREW-HP Launch 2013/3/1:21:11:29 Andrew ANDREW-HP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-35525242 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/3/1:21:11:32 Andrew ANDREW-HP === Setup ended ===
2013/3/1:21:11:31 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:21:11:31 Andrew ANDREW-HP Launch 2013/3/1:21:11:32 Andrew ANDREW-HP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:21:11:32 Andrew ANDREW-HP PageOpen LaunchDialog 2013/3/1:21:11:36 Andrew ANDREW-HP PageOpen LicenseDialog 2013/3/1:21:11:36 Andrew ANDREW-HP PageOpen ProductSelectionDialog2 2013/3/1:21:11:53 Andrew ANDREW-HP PageOpen LicenseDialog 2013/3/1:21:11:53 Andrew ANDREW-HP PageOpen LaunchDialog 2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen LicenseDialog 2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen ProductInfoDialog 2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen ProductSelectionDialog2 2013/3/1:21:17:44 Andrew ANDREW-HP PageOpen FullProgressDialog 2013/3/1:21:17:45 Andrew ANDREW-HP Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:17:52 Andrew ANDREW-HP Download User Pause VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:17:52 Andrew ANDREW-HP Download Paused VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:15 Andrew ANDREW-HP Download User Resume VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:38 Andrew ANDREW-HP Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:38 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/3/1:21:19:49 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/3/1:21:19:49 Andrew ANDREW-HP Download Skipped KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:49 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:19:52 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2013/3/1:21:19:53 Andrew ANDREW-HP Download Skipped KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:53 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:19:59 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2013/3/1:21:19:59 Andrew ANDREW-HP Download Skipped KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:59 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:06 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2013/3/1:21:20:07 Andrew ANDREW-HP Download Skipped KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:07 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:12 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2013/3/1:21:20:13 Andrew ANDREW-HP Download Skipped KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:13 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:15 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2013/3/1:21:20:16 Andrew ANDREW-HP Download Skipped KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:16 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:23 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2013/3/1:21:20:24 Andrew ANDREW-HP Download Skipped KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:24 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:30 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2013/3/1:21:20:30 Andrew ANDREW-HP Download Skipped KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:30 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/1:21:20:35 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2013/3/1:21:20:36 Andrew ANDREW-HP Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Error DIRECTX <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Error DIRECTX Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Aborted DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603 2013/3/1:21:42:47 Andrew ANDREW-HP Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:21:46:37 Andrew ANDREW-HP Download Complete FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:21:46:37 Andrew ANDREW-HP Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Andrew\AppData\Local\Temp\FaroSDK.log" 2013/3/1:21:47:08 Andrew ANDREW-HP Install FaroSDK Succeeded 2013/3/1:21:47:09 Andrew ANDREW-HP Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:37:37 Andrew ANDREW-HP Download Error RVT2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:38:06 Andrew ANDREW-HP Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:38:06 Andrew ANDREW-HP Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/1:23:38:06 Andrew ANDREW-HP Rollback FaroSDK Failed Failure is ignored, Result=1619 2013/3/1:23:38:29 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2013/3/1:23:38:47 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2013/3/1:23:39:05 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2013/3/1:23:39:16 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2013/3/1:23:39:34 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2013/3/1:23:39:52 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2013/3/1:23:40:10 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2013/3/1:23:40:23 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2013/3/1:23:40:23 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Any way to fix this from happening? Any help would be great.
I have requested your post be moved to the installation discussion group... They may be able to help you more then we can...
LD
Looks like your download from the student site is aborting.
The download process is very long. Please make sure you have a steady Internet connection and that it is not dropping or putting your NIC to standby mode when idle for a long period of time.
