Installation & Licensing
Revit & Inventor Client work on Windows Server 2012 R2?
2 REPLIES 2
631 Views, 2 Replies
Hi All,
In my lab we run some units with 2012 server for students to work with. Does Revit and Inventor 2015 run without issue on this?
Thanks!
2 REPLIES 2
TravisNave
The client applications are not supported on Server architecture. In fact, it is a violation of the license agreement.  However, Autodesk has partnered with Citrix if you are needing to remotely launch the software.
http://knowledge.autodesk.com/support/mudbox/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodesk...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Perfect. Thank you!
Administrator Productivity
