Hi All,
In my lab we run some units with 2012 server for students to work with. Does Revit and Inventor 2015 run without issue on this?
Thanks!
Solved by TravisNave. Go to Solution.
The client applications are not supported on Server architecture. In fact, it is a violation of the license agreement. However, Autodesk has partnered with Citrix if you are needing to remotely launch the software.
