Installation & Licensing
Revit 9 demo blocking Autocad server license problem?
1 REPLY 1
196 Views, 1 Reply
We are planning to implement Revit. In just the last two days several of our drafters installed Revit 9 in demo mode. One has had no problem, but two of them did; the next time they rebooted and tried to start Autocad 2006 they got an error about Autocad not finding the server license (?) and it wouldn't run. They had to uninstall Revit and run "repair installation" on Autocad from the control panel, and they were able to recover Autocad with all their settings.
Our IT Manager has a call in to our vendor. Has anyone else seen this problem or might have an idea as to what's going on and how to fix it? We really want to get drafters here started with learning how to use Revit. Thanks!
1 REPLY 1
TravisNave
This is a known error in Revit 9. I believe there is a patch for this or a brand new download of Revit 9 available. Might check into that or ask your Reseller.
Autodesk Forums:
Administrator Productivity
