Hi
I have tried to instal revit student several times and it keeps failing and giving me error messages
low image library failed result 1603
The redistributable failed result is 1619
I installed it on my last laptop but have recently upgraded to a HP pavilion. I know nothing of computers but am told it should easily manage the software.
it has an
AMD A8 processor
Radeon R5 graphics card
8GB RAM
1T hard drive
I have attached the set up log
After speaking to Autodesk on twitter for around 2 weeks i am now desperate
PLEASE HELP!!
Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Thank you for the help.
i have installled revit 2015. but there was no option for the student version.
its now asking for an activation key, i recently had it installed on my previous computer with a previous employer and they had it back when i changed jobs so i uninstalled it. however, i do not have the key.
can you help with this please?
You need to download the full version from the virtual agent. There is no "student" versions. It is all the same. It is just the way you license it that changes its behavior. Hope that makes sense.
