I need some help with my Maya 2011 Maya 2011 Entertainment Creation Suite Subscription Advantage Pack install on Win 7 64bit, which unable to locate the license or license server.
I installed the Network License Server and obtained a license, then confirmed it was running as a service. This is on the same machine Maya is to be installed on, called Workstation.
Then I installed Maya 2011 Subscription Advantage Pack, but when starting Maya, it asks for a license file or server to be specificed. If i specify the server, it says the Server (Workstation) is not respoding, if i specify the license file (the one obtained from Autodesk), I get an error, saying a valid license could not be obtained by the server [-15.570.0]. The server status appears fine, although there does appear to be errors in the diagnostics related to the license file.
Also a second server instance was created when i installed Maya 2011 after the Network License Manager, called "FLEXlm License Server" which specifies "C:\Program Files\Common Files\Alias Shared\Licensing\etc\lmgrd.exe" as the executable and "c:\FlexLm\aw_WORKSTATION.dat" as the license. This server instance, is not running and is not specified to run as a service, so have simply left it alone for the time being.
Server log, staus and diagnostics are below:
Log
15:33:58 (lmgrd)
15:33:58 (lmgrd)
15:33:58 (lmgrd) pid 1740
15:33:58 (lmgrd) Detecting other license server manager (lmgrd) processes...
15:34:01 (lmgrd) Done rereading
15:34:01 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 x64_n6) started on Workstation (IBM PC) (10/7/2010)
15:34:01 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
15:34:01 (lmgrd) US Patents 5,390,297 and 5,671,412.
15:34:01 (lmgrd) World Wide Web: http://www.acresso.com
15:34:01 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\MYECS2011enlicense.lic
15:34:01 (lmgrd) lmgrd tcp-port 27000
15:34:01 (lmgrd) Starting vendor daemons ...
15:34:01 (lmgrd) Starting vendor daemon at port 2080
15:34:01 (lmgrd) Using vendor daemon port 2080 specified in license file
15:34:01 (lmgrd) Started adskflex (pid 2092)
15:34:01 (adskflex) Unable to initialize access to trusted storage: 1
15:34:01 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79971 x64_n6
15:34:02 (adskflex) Server started on Workstation for:
15:34:02 (adskflex) 85512MYECS_F (consisting of: 85620MYECS_2011_0F
15:34:02 (adskflex) 85511MYECS_2010_0F)
15:34:02 (adskflex) 85537MAYAMFS_F (consisting of: 85537MAYAMFS_2011_0F
15:34:02 (adskflex) 85400MAYAMFS_2010_0F)
15:34:02 (adskflex) 85537MAYAMMR_F (consisting of: 85537MAYAMMR_2011_0F
15:34:02 (adskflex) 85400MAYAMMR_2010_0F)
15:34:02 (adskflex) 85537MAYAMMR1_F (consisting of: 85537MAYAMMR1_2011_0F
15:34:02 (adskflex) 85400MAYAMMR1_2010_0F)
15:34:02 (adskflex) 85537MAYAMMR3_F (consisting of: 85400MAYAMMR2_2010_0F
15:34:02 (adskflex) 85537MAYAMMR3_2011_0F)
15:34:02 (adskflex) 85537MAYAMMR4_F (consisting of: 85537MAYAMMR4_2011_0F
15:34:02 (adskflex) 85400MAYAMMR4_2010_0F)
15:34:02 (adskflex) 85537MAYAMMR5_F (consisting of: 85537MAYAMMR5_2011_0F
15:34:02 (adskflex) 85400MAYAMMR5_2010_0F)
15:34:02 (adskflex) 85537MAYAMMR2_F (consisting of: 85537MAYAMMR2_2011_0F
15:34:02 (adskflex) 85400MAYAMMR2_2010_0F) PLIST
15:34:02 (adskflex) EXTERNAL FILTERS are OFF
15:34:02 (lmgrd) adskflex using TCP-port 2080
15:35:53 (adskflex) TCP_NODELAY NOT enabled
Status
Flexible License Manager status on Thu 10/7/2010 16:14
[Detecting lmgrd processes...]
License server status: 27000@Workstation
License file(s) on Workstation: C:\Program Files\Autodesk Network License Manager\MYECS2011enlicense.lic:
Workstation: license server UP (MASTER) v11.7
Vendor daemon status (on Workstation):
adskflex: UP v11.7
Feature usage info:
Users of 85512MYECS_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of PLIST: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMFS_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR1_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR3_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR4_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR5_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR2_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR2_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMMR2_2010_0F: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 85537MAYAMMR5_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMMR5_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR4_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMMR4_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR3_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR1_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMMR1_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMMR_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMMR_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85537MAYAMFS_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85400MAYAMFS_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85620MYECS_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85511MYECS_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Diagnostics
FLEXnet diagnostics on Thu 10/7/2010 16:15
License file: C:\Program Files\Autodesk Network License Manager\MYECS2011enlicense.lic
"85512MYECS_F" v2.000, vendor: adskflex
License server: Workstation
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature: 85512MYECS_F
License path: C:\Program Files\Autodesk Network License Manager\MYECS2011enlicense.lic;
FLEXnet Licensing error:-125,147
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
"PLIST" v2.000, vendor: adskflex
This license can be checked out
"85537MAYAMFS_F" v2.000, vendor: adskflex
Feature: 85537MAYAMFS_F
"85537MAYAMMR_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR_F
"85537MAYAMMR1_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR1_F
"85537MAYAMMR3_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR3_F
"85537MAYAMMR4_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR4_F
"85537MAYAMMR5_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR5_F
"85537MAYAMMR2_F" v2.000, vendor: adskflex
Feature: 85537MAYAMMR2_F
"85537MAYAMMR2_2011_0F" v2.000, vendor: adskflex
"85400MAYAMMR2_2010_0F" v2.000, vendor: adskflex
"85537MAYAMMR5_2011_0F" v2.000, vendor: adskflex
"85400MAYAMMR5_2010_0F" v2.000, vendor: adskflex
"85537MAYAMMR4_2011_0F" v2.000, vendor: adskflex
"85400MAYAMMR4_2010_0F" v2.000, vendor: adskflex
"85537MAYAMMR3_2011_0F" v2.000, vendor: adskflex
"85537MAYAMMR1_2011_0F" v2.000, vendor: adskflex
"85400MAYAMMR1_2010_0F" v2.000, vendor: adskflex
"85537MAYAMMR_2011_0F" v2.000, vendor: adskflex
"85400MAYAMMR_2010_0F" v2.000, vendor: adskflex
"85537MAYAMFS_2011_0F" v2.000, vendor: adskflex
"85400MAYAMFS_2010_0F" v2.000, vendor: adskflex
"85620MYECS_2011_0F" v2.000, vendor: adskflex
"85511MYECS_2010_0F" v2.000, vendor: adskflex
Requests from the same USER/HOST do not consum-----------------------------------------------------
(please note the diagnostic is cut off at end here)
Solved by TravisNave. Go to Solution.
Solved by hashim.mundol. Go to Solution.
The error in the Diagnostics (A PACKAGE component must be specified.) can be ignored.
The issue here could be due to ipv6 on the machine.
there are few work arounds
This thread has similar issue with Autocad 2011 (since licensing is almost similar for Mays 2011 this might help)
http://forums.autodesk.com/t5/AutoCAD-2011/64bit-licensing-error-15-570-0/td-p/2693521
Or you could try do a loopback network address resolution in the hosts file
as documented here
http://usa.autodesk.com/getdoc/id=TS14077688
if none of the workaround resolves the issue please try to create a diagnostic variable to get detailed error on the client side(when you start Maya)
http://usa.autodesk.com/getdoc/id=TS1065188
(this is applicaple to Maya too, except the path the log would be in the Maya bin directory)
This error is almost surely an IPv6 issue. What you can do to verify this is open a command prompt and PING workstation. If it comes back with an IPv6 address or a local :1 loopback address, then you need to rectify it.
The easiest way is to modify your hosts file located at C:\Windows\System32\Drivers\etc. Edit it and remove the localhost entry for :1 and replace it with 127.0.0.1. If you are using a static IP address, then you should also add Workstation to your IPv4 static address as well. At that point, you should be able to PING workstation and it will come back with the correct IPv4 address. Your product should then launch successfully.
Thanks Travis and Hashim,
It was an IPv6 issue, so disabled IPv6 on the adapter, then did the registery fix, but still didn't solve the problem. However editing the host file and adding the local loopback to the static Ip address of the machine did get it working.
