Installation & Licensing
License Scheme Question
4 REPLIES 4
422 Views, 4 Replies
Regarding to our entity planning to develop a new subsidiary company and would like to assess the feasibility on sharing the AutoCAD license.
If possible, would like to know about :
1)    Without change the license owner, can we share with the subsidiary company? Any documents have to provide? Any region restriction?
2)    If necessary to transfer the license, any procedure have to do?
4 REPLIES 4
TravisNave
My recommendation is to start with reading about the TOL.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18571898&linkID=9240617
Then you can contact your Reseller for additional help.
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Grateful for your advise. And tried to call my reseller but not sure on my situation. Since my working company would like to build up a subsidiary company and wanna assess the license can be share with the subsidiary company or not. And won't be change the owner of the mother company.
grace.liu
Hi raymondllw,
Welcome to the community!
The definition of licensee in the Autodesk License and Service agreement, the licensee only to a single, specifically identified legal entity or individual, and does not include any subsidiary or affiliate of any such legal entity or individual or any other related person. So the licenses only be access and use by the licensee. If you want to access/use them in other legal entity, please follow up the Transferring Ownership of Autodesk Licenses procedure.
Hope this information will help you.
Grace Liu
in reply to: grace.liu
Thank you so much
Administrator Productivity
