Installation & Licensing
License Error 0.0.0
16 REPLIES 16
Message 1 of 17
rkidwell
7550 Views, 16 Replies
License Error 0.0.0
I recently installed the Network License Manager on a server and activated our license for Design Academy 2010, which is a 125 seat license. The server is running, and checking the server status confirms that we have 125 seats and it displays how many are in use at that time.
I created a single deployment for one of our labs and installed it on 30 workstations. The first 29 workstations pick up a license just fine and the software runs. The last computer I deployed returns the following error when I try to run any of the software included with Design Academy:
A valid license could not be obtained by the network license manager
Error [0.0.0]
This error appears regardless of how many other licenses are in use...whether it's 0 or 29. Any ideas?
Machine details:
1. All 30 machines are cast from the same image
2. OS is XP Pro SP2
3. No network issues on any of the machines
4. IP's and Host Names are all unique
5. Antivirus versions and DAT files are all identical
6. Firewall service is disabled on all machines
There are some leftovers from previous installations on all machines, but just for troubleshooting I uninstalled 2010, removed all Autodesk directories I could find and reinstalled 2010 from the same deployment. Same problem.
Right now I am preparing to install the deployment on another machine, but was hoping someone might have some ideas for me.
16 REPLIES 16
Message 2 of 17
rkidwell
in reply to: rkidwell
Stupid me....after a few hours of troubleshooting, I didn't think to check the date on the client machine.
Problem solved.
Message 3 of 17
What does the date on the machine have anything to do with it?
I am the only person in our small company that has a network license. So this is an area (network management) that receives little attention from me or anybody.
Brad
Message 4 of 17
rkidwell
Not sure, but the date may have to be the same as the one on the license server. All I know is that it resolved my issue. Another tech here had a few machines with the same problem. I had him check the dates and everything worked perfectly.
Message 5 of 17
I am having the same trouble
Error [0.0.0]
Have checked the date and time settings between the server that the licence software sits on and the client machines, all seems to be ok, however withiin the licence software itself I notice under the system settings tab that the ethernet address is just showing as ffffffff?  and the MSDOS time and GMT time are an hour apart?
Any ideas anyone
Message 6 of 17
hashim.mundol
Please install the ipv6 patch for the license manager
http://usa.autodesk.com/getdoc/id=DL10976858
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 7 of 17
Thanks for that,
I gave it a try but unfortunately after running the update still getting the same error message.
Message 8 of 17
hashim.mundol
Stuart
OK do you have bridged/teamed network adapters ?
this would cause mac address to be ffffffff
Hashim Mundol
Autodesk, Inc.
Message 9 of 17
in reply to: hashim.mundol
Yeh,
They are teamed up
Message 10 of 17
hashim.mundol
This is not supported network adapter, you have to use single adapter
http://usa.autodesk.com/getdoc/id=TS1056498
Hashim Mundol
Autodesk, Inc.
Message 11 of 17
My LMGR is a Win2k3 Server and it is a virtual machine (by Virtual Server 2005 R2 Sp1) into a physical DC Win2k3 server.
I've created installation packet of Autodesk Electrical 2011 and I've installed it on a client (WinXp Sp3) on the same domain of DC Win2k3 Server.
When I click on Autodesk Electrical 2011 icon on the desktop, I see the same error of rkidwell (first message).
I ask to Product Support an help to solve my problem.
Thanks.
Mr. Giuseppe Mianulli
Message 12 of 17
TravisNave
Make sure that your MAC address of your virtual machine's NIC is set manually and that it matches the address listed in your LIC file.  Make sure that your NLM is running and shows licenses of your 2011 product are available.  Then ping the NLM server from your client and ensure that you have a proper IPv4 response.  Your product should launch.
Autodesk Forums:
Message 13 of 17
in reply to: TravisNave
Hi TravisNave,
thanks for your reply, very interesting!
About NLM, I've installed on my Lmgr Server 2011 version.
About MAC address of my virtual machine's NIC, it is set as a dynamic address but in my lic file, it is listed correctly.
If I change it from dynamic to static, I think it doesn't change...is it correct?
Tomorrow (today I'm not in my office) I'll test ping from client to Lmgr server but I think it is ok.
Thank you for now.
Message 14 of 17
TravisNave
Yes, you want the ethernet hardware address to always be set manually on a VM machine.  Otherwise when it mysteriously decides to change itself, your LIC will be invalid.  Good luck!
Autodesk Forums:
Message 15 of 17
Hi TravisNave,
I confirm that the problem of this post has been resolved.
Thank you very much.
Message 16 of 17
Jessup
Hello Travis,
Thank you for the information in message 12 about the virtual servers. It helped me resolve this [0.0.0] licensing error, "Valid license could not be obtained by the network license manager. [0.0.0]", on a telephone call today.
The end user wanted me to update this thread with our solution, as he found a “why”, so to speak, to explain the issue from his side of things, and I want to update this because we do not have it documented anywhere else yet.
In this case: The end user was trying to launch AutoCAD Mechanical 2012 from the Autodesk Product Design Suite Standard 2012. (I do not know if other products from the suite had been tried yet. I do not believe they had since this was a new configuration that never worked yet.)
- The server is a virtual server running on a physical server. Virtual Machine (VM) running on VMware vSphere 4.0 (would also apply to also ESX 3.5, vSphere 4.1 etc).
- The MAC Address that was being reported by the virtual server matched the MAC Address in the license file.
- The LMTOOLS server status enquiry said that it was running and issuing the correct number of seats.
- The LICPATH.LIC file had the correct server host name in it.
What happened is (in the words of the end user): We had a physical server which we virtualized in a physical to virtual migration. The MAC that it kept for the virtual NIC was the physical MAC Address, as a result of the migration.
To resolve this issue, I converted it to a VMWare MAC Address instead of the physical MAC Address and set it to static. We got the new license file at www.autodesk.com/register, configured LMTOOLS with the new license file, and it worked.
Thanks again Travis. I am marking the post number 12 as an accepted solution. Best regards,
Jessup H.
Support Specialist
Product Support
Autodesk, Inc.
Message 17 of 17
TravisNave
in reply to: Jessup
Excellent.  Thanks for the update.  Always glad to help.  I've seen just about every odd situation that can happen with the NLM and with many customers moving to virtual machines, we'll probably see more of this in the future.
Autodesk Forums:
Administrator Productivity
