Welcome to thew forum.
When you did a reinstall did you do a Clean Uninstall
first? If not the system probably still has info in the registry from the initial install.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Many have had luck with the clean reinstall, as Scott mentioned. Others have had luck with reinstalling .NET.
See this article:
Good Luck!
Hello. This is a difficult issue. If the prior suggestions do not help, and you really need this working, I would reformat Windows and start over. I know it might be a pain, but the hour it takes to do this is probably going to save you 20 hours of frustration and testing that may ultimately not solve the issue. Something is out of sync and buried in the OS somewhere.
A NET uninstall and reinstall is usually the best solution.
Thank you for taking part in our community!
@Anonymous wrote:
Cheers, I was wondering if you had a link to the steps to try a clean uninstall that I could follow?
Now that I am back in the office, I can use my macros!
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Hope that helps. Otherwise, you'll likely have to revert to an OS reinstall. Good Luck!
