Installation & Licensing
425 Views, 3 Replies
Install Question
I have my LMTOOLS server all set up, so now I'm ready to install the software.  Do I have to create a network install package, or can I just install everything using the DVDs?  I'm going to create an image based off this computer, so the whole network install thing isn't necessary.  The software will never be used anywhere else other than this lab.
Thanks for your help.
3 REPLIES 3
DarrenP
probably easier to create a deployment of the software it depends on how many computers you have to install it on
DarrenP
in reply to: DarrenP
I only have to really install it on 1 computer, then I'm going to pull an image of that computer and push it to 30 others.
TravisNave
In that case, you can install once from disc as a network version and then make your clone image. This is only supported for network seats, so you should be fine.
Autodesk Forums:
Administrator Productivity
