Installation & Licensing
Install after download of Civil 3D
6 REPLIES 6
1447 Views, 6 Replies
I have tried four times to install AutoCAD Civil 3D 2015. Every time I get it downloaded then try to install, on the installation page AutoCAD Civil 3D 2015 is not checked. When I try to click the checkbox for the installation nothing happens. Any suggestions on what is wrong. After each time trying to install I go back and un-install anything that did install, so my control panel is clear of all Autodesk programs except the download manager. Thanks!
6 REPLIES 6
TravisNave
Can you provide a screen shot by chance?
Also, you meet requirements right?  No XP or Vista.  And Win7 has to be SP1.
Autodesk Forums:
rkmcswain
Have you tried downloading the entire package and installing from that, as opposed to using the download manager...
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
R.K. McSwain     | CADpanacea | on twitter
in reply to: TravisNave
Sorry, I can't provide a screen shot. I have Windows 7 Ultimate 64 bit. The download goes fine but, when the installation page appears the check box next to AutoCAD Civil 3D is unchecked and I ca't get it to accept a check mark.
in reply to: rkmcswain
I have tried every method for downloading. The download works fine but, when the installation page appears there is no check mark in the check box for AutoCAD Civil 3D. I have clicked the check box repeatedly but it won't accept the check.
I forgot to say, yes I have SP1.
Thanks! That did it.
Administrator Productivity
