My Instalation of 3dsMAx fails.
Tried auto download, manual download, manager install etc.
Log attached.
Windows 7 enterprize
Intel Xeon X5650 @ 2.67GHz
Ram 24 gb
64 bit
Nvidia Quadro FX3800
Solved by TravisNave. Go to Solution.
Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
It sounds fairly easy and to the point.
I'll try this solutiona as soon as my It people are back from vacations. Thanks and happy Holidays!
