Installation & Licensing
AutoCAD LT 2015 - Subscription Installation Issues
1 REPLY 1
259 Views, 1 Reply
Purchased a subscription for AutoCAD LT 2015 and have tried the three delivery methods to no avail.
For the 'Install Now' - I download the required file, start it and it disappears.
For the 'Download Now' - I get a connection error
For the 'Browser Download' - I downloaded the 1 GB+ file, opened it and it tells me it is for a 32 bit installation and cannot be opened.
Using Window 8
Any help is appreciated.  Thank you.
1 REPLY 1
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Get the 64-bit version of AutoCAD LT 2015.  Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
