Installation & Licensing
edarlak
304 Views, 4 Replies
Home SN request
My company has been using Inventor since Version 5.3.  Our vendors at that time told us we were allowed to install a copy at work and at home, per SN.
What release did this request for home use SN that cuts off after 13 months stuff start?
Does the home SN give same functionality?  Will vault work over VPN from home with this home SN?
4 REPLIES 4
TravisNave
in reply to: edarlak
The HULA license is a fully licensed serial that simply expires after 13 months. Your program will behave as expected and Vault will indeed continue to work over VPN. The expiration simply protects your asset and prevents abuse. It can be renewed.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
philip.s
Thanks Travis,
Eugene, I also wanted to point out that Home Use Licenses are only available to subscription customers with an active agreement. Please review the following Extending Your License Rights Tutorial for more info.
edarlak
in reply to: philip.s
Yes, we are on a subscription.
I'm just wondering when this started?  I was not made aware of the need to request a special home SN until now, not by Autodesk or my Vendor.
Is this a reletively new requirment?
philip.s
To the best of my knowledge the Home Use License benefit was rolled out in or around 2008, however there were a couple of different variations that existed a year or two prior.
Administrator Productivity
