When I try to install AutoCAD 2024 on my machine, it stops at around 12% and displays 'The install couldn't finish. Error 4000'
I have tried following the steps in this article, but to no avail. I also made sure to grant all the necessary permissions as instructed here to the installer and disabled the antivirus and firewall, but these steps also didn't help.
I will attach the latest setup log that I've obtained using the Installation Log Collection Tool.
Solved by Simon_Weel. Go to Solution.
The log says odisver xml path does not exist###process completed with non-zero exit code: 4000
I notice the installer path (C:\Users\ANDR~1\AppData\Local\Temp\o...) listed as a 'user' and not administrator. You need admin permission to install AutoCAD.
I agree that you should install with local admin rights. I would also recommend that you create a new TEMP folder on C:\ and point your %TEMP% and %TMP% user environment variables to this new folder. Then make sure you install with your anti-virus temporarily disabled.
I have some instructions on how to change your %TEMP% folders at this link here:
Just change the value to C:\TEMP after creating that directly. It will help your installation a lot by getting those temporary files out of your user account. It'll be easier to keep cleaned up as well.
Good Luck!
That was it! Thank you so much.
I switched to the administrator account, and there I was able to install it flawlessly.
