Installation & Licensing
Deploy standalone versions
4 REPLIES 4
248 Views, 4 Replies
Have 10 AIP's standalone licenses to install.
Is is possible to create a deployment to install these, and then on each machine register the instalation?
4 REPLIES 4
TravisNave
Yes. Create a deployment with the Deployment Wizard and choose stand-alone as the license type. Uncheck the silent mode box and that will allow each user to put in their own name and potentially different serial numbers if necessary.
Autodesk Forums:
What happens is when i'm creating a deployment, i'm asked for a serial number before i can configure the options. I have indeed 10 s/n!! Will i still be asked for each serial number when running the deployment in non-silent mode, even though i was asked for one s/n before?
As I recall, if you run in non-silent mode, it stops at the SN page, and
while showing the initial SN you created the deployment with, you can enter
new numbers at that time.
John
wrote in message news:5670028@discussion.autodesk.com...
TravisNave
That is correct.
In the future, you might have your reseller/Autodesk combine all of your different license codes into one Group Number. Then you won't have this problem anymore.
Autodesk Forums:
Administrator Productivity
