Installation & Licensing
Blue Screen during Installation - can't reinstall
5 REPLIES 5
756 Views, 5 Replies
While installing Autodesk Inventor 2011 the computer had a blue screen.
Obviously the program didn't finish installing so attempted to uninstall, but it won't uninstall.
Have tried the steps at http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9242018&id=14893355&siteID=123112 (TS14893355). The Uninstall tool fails, so followed the steps to manually uninstall, however when trying to reinstall Inventor the option to install it is greyed out and it says Inventor is already installed.
Any other ideas on how to fix this issue and reinstall Inventor?
5 REPLIES 5
TravisNave
Yes, you need the Microsoft Installer Cleanup Utility to remove the installation registration from Add/Remove Programs.  I will attach it here.
Autodesk Forums:
in reply to: TravisNave
Thanks, will have to wait until Monday morning to test now. Will post back on Monday.
TravisNave
Sounds good.  Just install the program and then launch it from the Start Menu.  At that point, remove Inventor from the list and you will be set.
Autodesk Forums:
Thanks, worked like a charm!
TravisNave
Excellent!
Autodesk Forums:
Administrator Productivity
