Installation & Licensing
AutoCAD map 3D failed to install
1 REPLY 1
264 Views, 1 Reply
Hi community,
I am a GIS student and I would like to study AutoCAD map 3D.
But I failed so many times and I wish someone could help me out
Here is the log:
2014/10/31:13:25:49 jzhang PUFFERFISH === Setup started on PUFFERFISH by jzhang ===
2014/10/31:13:25:49 jzhang PUFFERFISH Path_Length: 155
2014/10/31:13:25:49 jzhang PUFFERFISH Current Directory C:\Autodesk\Autodesk_Map_2014_English_Win_32-64bit_wi_en-us
2014/10/31:13:25:49 jzhang PUFFERFISH Launch
2014/10/31:13:25:49 jzhang PUFFERFISH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/Autodesk_Map_2014_English_Win_32-64bit_wi_en-us_S... /SN 900-51983771 /PK 129F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/31:13:25:49 jzhang PUFFERFISH Current Directory C:\Users\jzhang\AppData\Local\Temp\_AI5B3C.tmp
2014/10/31:13:26:25 jzhang PUFFERFISH === Setup ended ===
2014/10/31:13:25:53 jzhang PUFFERFISH === Setup started on PUFFERFISH by jzhang ===
2014/10/31:13:25:53 jzhang PUFFERFISH Path_Length: 155
2014/10/31:13:25:53 jzhang PUFFERFISH Current Directory C:\Users\jzhang\AppData\Local\Temp\_AI5B3C.tmp
2014/10/31:13:25:53 jzhang PUFFERFISH Launch
2014/10/31:13:25:58 jzhang PUFFERFISH Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/SETUP_x64....
2014/10/31:13:26:24 jzhang PUFFERFISH Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/SETUP_x64....
2014/10/31:13:26:24 jzhang PUFFERFISH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\jzhang\AppData\Local\Temp\_AI5B3C.tmp\Setup\AcSetup.dll
2014/10/31:13:26:24 jzhang PUFFERFISH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/31:13:26:25 jzhang PUFFERFISH PageOpen LaunchDialog
2014/10/31:13:26:48 jzhang PUFFERFISH PageOpen LicenseDialog
2014/10/31:13:26:48 jzhang PUFFERFISH PageOpen ProductInfoDialog
2014/10/31:13:26:48 jzhang PUFFERFISH PageOpen ProductSelectionDialog2
2014/10/31:13:36:35 jzhang PUFFERFISH PageOpen FullProgressDialog
2014/10/31:13:36:39 jzhang PUFFERFISH Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/DIRECTX.ta...
2014/10/31:13:36:41 jzhang PUFFERFISH Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/DIRECTX.ta...
2014/10/31:13:36:41 jzhang PUFFERFISH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/31:13:37:30 jzhang PUFFERFISH Install DirectX Runtime Succeeded
2014/10/31:13:37:30 jzhang PUFFERFISH Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:38:00 jzhang PUFFERFISH Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/10/31:13:38:04 jzhang PUFFERFISH Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CM.tar.lzm...
2014/10/31:13:38:21 jzhang PUFFERFISH Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CM.tar.lzm...
2014/10/31:13:38:21 jzhang PUFFERFISH Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:39:06 jzhang PUFFERFISH Install Autodesk Material Library 2014 Succeeded
2014/10/31:13:39:10 jzhang PUFFERFISH Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CMILB.tar....
2014/10/31:13:39:24 jzhang PUFFERFISH Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CMILB.tar....
2014/10/31:13:39:24 jzhang PUFFERFISH Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:39:49 jzhang PUFFERFISH Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/10/31:13:39:49 jzhang PUFFERFISH Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:40:18 jzhang PUFFERFISH Install Autodesk Content Service Succeeded
2014/10/31:13:40:18 jzhang PUFFERFISH Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:40:26 jzhang PUFFERFISH Install Autodesk Content Service Language Pack Succeeded
2014/10/31:13:40:26 jzhang PUFFERFISH Installing Microsoft SQL Server Native Client 11.0:  IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/31:13:40:37 jzhang PUFFERFISH Install Microsoft SQL Server Native Client 11.0 Succeeded
2014/10/31:13:40:42 jzhang PUFFERFISH Download Play ACADMAP http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/ACADMAP_x6...
2014/10/31:13:47:23 jzhang PUFFERFISH Download Aborted ACADMAP http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/ACADMAP_x6...
2014/10/31:13:47:23 jzhang PUFFERFISH Install Autodesk® AutoCAD® Map 3D 2014 Failed Download Failed, Installation aborted, Result=1603
2014/10/31:13:47:35 jzhang PUFFERFISH Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2014/10/31:13:47:47 jzhang PUFFERFISH Rollback Autodesk Content Service Language Pack Succeeded
2014/10/31:13:48:04 jzhang PUFFERFISH Rollback Autodesk Content Service Succeeded
2014/10/31:13:48:46 jzhang PUFFERFISH Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/10/31:13:49:32 jzhang PUFFERFISH Rollback Autodesk Material Library 2014 Succeeded
2014/10/31:13:49:42 jzhang PUFFERFISH Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/10/31:13:49:42 jzhang PUFFERFISH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/31:13:49:46 jzhang PUFFERFISH PageOpen InstallCompleteDialog
2014/10/31:13:50:05 jzhang PUFFERFISH === Setup ended ===
2014/11/26:09:28:24 jzhang PUFFERFISH === Setup started on PUFFERFISH by jzhang ===
2014/11/26:09:28:24 jzhang PUFFERFISH Path_Length: 155
2014/11/26:09:28:24 jzhang PUFFERFISH Current Directory C:\Autodesk\Autodesk_Map_2014_English_Win_32-64bit_wi_en-us
2014/11/26:09:28:24 jzhang PUFFERFISH Launch
2014/11/26:09:28:24 jzhang PUFFERFISH CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/Autodesk_Map_2014_English_Win_32-64bit_wi_en-us_S... /SN 900-51983771 /PK 129F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/26:09:28:24 jzhang PUFFERFISH Current Directory C:\Users\jzhang\AppData\Local\Temp\_AIA193.tmp
2014/11/26:09:28:33 jzhang PUFFERFISH === Setup ended ===
2014/11/26:09:28:25 jzhang PUFFERFISH === Setup started on PUFFERFISH by jzhang ===
2014/11/26:09:28:25 jzhang PUFFERFISH Path_Length: 155
2014/11/26:09:28:25 jzhang PUFFERFISH Current Directory C:\Users\jzhang\AppData\Local\Temp\_AIA193.tmp
2014/11/26:09:28:25 jzhang PUFFERFISH Launch
2014/11/26:09:28:30 jzhang PUFFERFISH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/SETUP_x64....
2014/11/26:09:28:31 jzhang PUFFERFISH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\jzhang\AppData\Local\Temp\_AIA193.tmp\Setup\AcSetup.dll
2014/11/26:09:28:31 jzhang PUFFERFISH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/26:09:28:34 jzhang PUFFERFISH PageOpen LaunchDialog
2014/11/26:09:29:20 jzhang PUFFERFISH PageOpen LicenseDialog
2014/11/26:09:29:20 jzhang PUFFERFISH PageOpen ProductInfoDialog
2014/11/26:09:29:20 jzhang PUFFERFISH PageOpen ProductSelectionDialog2
2014/11/26:09:29:25 jzhang PUFFERFISH PageOpen FullProgressDialog
2014/11/26:09:29:25 jzhang PUFFERFISH Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/DIRECTX.ta...
2014/11/26:09:29:25 jzhang PUFFERFISH Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/26:09:30:21 jzhang PUFFERFISH Install DirectX Runtime Failed Failure is ignored, Result=-9
2014/11/26:09:30:21 jzhang PUFFERFISH Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:31:00 jzhang PUFFERFISH Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/11/26:09:31:00 jzhang PUFFERFISH Download Skipped CM http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CM.tar.lzm...
2014/11/26:09:31:00 jzhang PUFFERFISH Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:32:03 jzhang PUFFERFISH Install Autodesk Material Library 2014 Succeeded
2014/11/26:09:32:04 jzhang PUFFERFISH Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/CMILB.tar....
2014/11/26:09:32:04 jzhang PUFFERFISH Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:32:53 jzhang PUFFERFISH Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/11/26:09:32:53 jzhang PUFFERFISH Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:34:04 jzhang PUFFERFISH Install Autodesk Content Service Succeeded
2014/11/26:09:34:08 jzhang PUFFERFISH Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:34:21 jzhang PUFFERFISH Install Autodesk Content Service Language Pack Succeeded
2014/11/26:09:34:22 jzhang PUFFERFISH Installing Microsoft SQL Server Native Client 11.0:  IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/11/26:09:34:44 jzhang PUFFERFISH Install Microsoft SQL Server Native Client 11.0 Succeeded
2014/11/26:09:34:49 jzhang PUFFERFISH Download Play ACADMAP http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/ACADMAP_x6...
2014/11/26:09:45:14 jzhang PUFFERFISH Download Aborted ACADMAP http://edutrial.autodesk.com/SWDLDNET3/2014/MAP/WI/{8A5326A8-8CD6-419B-90D3-0F2568E3C7E2}/ACADMAP_x6...
2014/11/26:09:45:15 jzhang PUFFERFISH Install Autodesk® AutoCAD® Map 3D 2014 Failed Download Failed, Installation aborted, Result=1603
2014/11/26:09:45:38 jzhang PUFFERFISH Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2014/11/26:09:46:06 jzhang PUFFERFISH Rollback Autodesk Content Service Language Pack Succeeded
2014/11/26:09:47:10 jzhang PUFFERFISH Rollback Autodesk Content Service Succeeded
2014/11/26:09:48:06 jzhang PUFFERFISH Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/11/26:09:49:54 jzhang PUFFERFISH Rollback Autodesk Material Library 2014 Succeeded
2014/11/26:09:50:05 jzhang PUFFERFISH Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
1 REPLY 1
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
Administrator Productivity
