Ugh... I've tried to install this multiple times already. Here's the log:
2012/7/3:12:49:07 Jorge #2 JORGESWORLD PageOpen ProductInfoDialog
2012/7/3:12:49:10 Jorge #2 JORGESWORLD PageOpen LicenseDialog
2012/7/3:12:49:11 Jorge #2 JORGESWORLD PageOpen BeginDeploymentDialog
2012/7/3:12:49:12 Jorge #2 JORGESWORLD PageOpen LaunchDialog
2012/7/3:12:49:13 Jorge #2 JORGESWORLD PageOpen LicenseDialog
2012/7/3:12:49:15 Jorge #2 JORGESWORLD PageOpen ProductInfoDialog
2012/7/3:12:49:22 Jorge #2 JORGESWORLD PageOpen ProductSelectionDialog2
2012/7/3:12:50:23 Jorge #2 JORGESWORLD PageOpen FullProgressDialog
2012/7/3:12:50:24 Jorge #2 JORGESWORLD Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JORGE#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/7/3:12:50:25 Jorge #2 JORGESWORLD Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2012/7/3:12:50:29 Jorge #2 JORGESWORLD PageOpen InstallCompleteDialog
2012/7/3:12:50:50 Jorge #2 JORGESWORLD === Setup ended ===
2012/7/3:13:26:16 Jorge #2 JORGESWORLD === Setup started on JORGESWORLD by Jorge #2 ===
2012/7/3:13:26:16 Jorge #2 JORGESWORLD Launch
2012/7/3:13:26:30 Jorge #2 JORGESWORLD === Setup ended ===
2012/7/3:13:26:22 Jorge #2 JORGESWORLD === Setup started on JORGESWORLD by Jorge #2 ===
2012/7/3:13:26:22 Jorge #2 JORGESWORLD Launch
2012/7/3:13:26:30 Jorge #2 JORGESWORLD PageOpen LaunchDialog
2012/7/3:13:26:34 Jorge #2 JORGESWORLD PageOpen LicenseDialog
2012/7/3:13:26:37 Jorge #2 JORGESWORLD PageOpen ProductInfoDialog
2012/7/3:13:27:19 Jorge #2 JORGESWORLD PageOpen ProductSelectionDialog2
2012/7/3:13:27:23 Jorge #2 JORGESWORLD PageOpen FullProgressDialog
2012/7/3:13:27:24 Jorge #2 JORGESWORLD Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JORGE#~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/7/3:13:27:25 Jorge #2 JORGESWORLD Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
I already uninstalled the newer versions of Microsoft Visual C++ Redistributable. Any help? I blame Autodesk's failure to keep up with newer releases of Redistributable.
Install the latest verison. Then remove the prerequisite check from the setup.ini file.
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
