AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
License transfer between 32 and 64 bit machines and then back to
3 REPLIES 3
532 Views, 3 Replies
Question :
Can I transfer my license back and forth from my laptop (32bit) and my work station (64bit) using the license transfer utility?
3 REPLIES 3
Alfred.NESWADBA
yes
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
thepworth
Better question - Are you on Subscription?
If so, you can have 1 license for your "Work" workstation and request "home use" for your laptop....
Look in your subscription center / talk to your reseller for details.
Cheers!
TravisNave
True.  You should just activate both as the EULA allows for exactly what you are asking.  Forget the LTU as it is problematic.
Autodesk Forums:
”Boost
