Revit freeze when trying to save
1 REPLY 1
410 Views, 1 Reply
I recently reinstalled Revit architecture 2011 and now I am unable to save any work.  When I save or save as, Revit simply freezes.  If I hit esc it returns to a functioning status without saving.  It is a Network License on single license server, if that makes any difference.  Any help would be appreciated.
1 REPLY 1
TravisNave
Welecome to the community.
Are you saving locally or to a network resource?  Also, what is your OS?
Make sure you have local admin rights, UAC off, and an exception made for your anti-virus.
Good Luck!
Autodesk Forums:
Forma Design Contest
